Results 1 to 2 of 2
Thread: Sunbeam EM5600 + EM0450 extraction
    Dec 2011
    1
    Just upgraded to a new EM0450 grinder with an unpressurised portafilter basket for my Sunbeam EM5600 and cant seem to get a proper extraction :( :( :(
    There is pretty much two scenarios that occur:
    1. I grind too course and the shot is extracted too quickly (tried a harder tap but this didnt really help)
    2. I grind finner and the group handle turn and it seem like the pressure is too much for the machine... :-/
    Any ideas guys? :-?
    Dec 2008
    1,049
    Re: Sunbeam EM5600 + EM0450 extraction
    Welcome and nice to hear the upgrade :)
    how many clicks are there between "too fine" and "too coarse"? The "sweet spot" is a on a kife edge, and small changes either side will produce (as youve found) gushers or blockers ;D
    Unfortunately some grinders make the steps too large so you cant get right on top of that sweet spot.
    If this is the case, and theres only one click between gushing or blocked, stick to the blocked setting but tamp lighter and dose less.
    Also, what beans and when were they roasted? If theyre older than 2/3 weeks from the roast date, youll have to grind finer, potentially pushing you over the limit.
    Hope that helps :)
  1. Sunbeam EM5600
    By KayEnn in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th July 2010, 05:15 PM
  2. EM5600 + EM0450 issues
    By raab in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th April 2010, 02:07 PM
  3. Help with Sunbeam EM5600
    By Mdhatter in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 18th May 2008, 06:56 AM
