Results 1 to 3 of 3
Thread: Presso or Breville 800ES?
    jimmycth
    I am new and was hoping to get some advice here. I am indecisive of what I should get between the two. A few non-sponsors are having a deal with the Breville coupled with the BCG450 grinder. Was thinking of getting a Breville BCG800 smart grinder if Im getting the Presso. What should I get? How are they in terms of reliability as I will be leaving Aussie to a place where both brands are not sold?
    Thank you in advance.
    Dec 2008
    1,049
    Re: Presso or Breville 800ES?
    In either case skip the BCG450 - its not fine enough for anything but perhaps plungers, especially if youre going to go the path of unpressurised baskets, fresh beans, etc. The smart grinder is excellent - see if they can do a deal on that, it will handle many machines above the 800ES.
    Presso or Espresso? Theyre different, sure. I would find somewhere you can taste them both, as they are different. How many do you want to make at a time, what about milk, etc. Presso is surely simpler than a Breville, which may help with breakages if youre out of "range". Ive never tasted a presso so I dont know for sure.
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    I can personally tell you that the BCG800 works fine with the Presso, it is the exact two that I am using at present.
    Weve always loved what the Presso produces.
    The interesting thing about the BCG800 with the Presso is that I am using a much finer grind with it than for the BES900.
    Given those two choices I would go with the Presso :)
  1. Will an Breville Ikon pf work on a Breville 800ES??
    By jkwa in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 18th February 2012, 01:45 PM
  2. !!!GONE!!! - Breville 800ES
    By Dr_Beer in forum Paid Forward - Taken
    Last Post: 8th December 2011, 10:58 PM
  3. Replies: 7
    Last Post: 11th June 2009, 08:33 PM
