Results 1 to 10 of 10
Thread: de-pressurized em3500 basket!
    Oct 2011
    Perth, Western Australia, Australia
    95
    CoffeeSnobs is a bad influence on my life...
    See what you made me do?
    I got in trouble with the site manager next door for not wearing my steel caps when I went in to use the angle grinder... :)* at least I had my white card on me.
    Oct 2011
    95
    Re: de-pressurized em3500 basket!
    I now get real crema that dissappears far too quickly on my aging robusta dark roast but tastes much less like soda water.
    Dec 2008
    1,049
    wow - what about the large hole damage on the far side?
    Are you sure one of those plates wasnt pressed on? Its easy to cold press a cup shaped filter in the factory, but you cant press a double sided filter in one go so the second piece is usually pushed in later - which means its usually easy to remove it before you do the cutting. My breville double sided filter came apart with some hard bangs on the table! Then I drilled out the single-hole side and pushed the filter bottom back in...
    Oct 2011
    95
    Quote Originally Posted by 212921262C2A480 link=1328702065/2#2 date=1328746287
    Oh thats just the shadow from the camera angle. Its just a flake of stainless that hasnt come up entirely. Works beautifully, now. A lot more is getting extracted (this plus the grinder means I have to cut in half the dose to get the coffee I want).
    Dec 2008
    1,049
    phew! I was beginning to wonder! Youre on the road now - my next purchase after drilling out my baske was a HX ::)
    Dec 2004
    Earth!
    16,325
    [split] [link=http://coffeesnobs.com.au/YaBB.pl?num=1328874956/0#0][splithere][/link][splithere_end]
    Oct 2011
    95
    Okay, so now that I can grind coffee fine enough to slow the pour to a drip followed by a trickle, Im wondering two things:
    I have the impression from various threads that the appropriate time for a (double) shot of espresso varies from machine to machine - 10 seconds to 30 seconds to who knows??? Can somebody comment on this? As well as maybe what the ideal time might be for the ol em3500?
    2ndly, another thing I have read form folks is that they run the steam wand a couple minutes to superheat the thermoblock before pouring their shot. I dont really understand what thats supposed to achieve and the result of my trying this is that my pour quickly turns to a live-steam coffee-burning session which doesnt help my flavour much. Ive been more satisfied with pours without the pre-heat. Whats the deal. Somebody help demystify this for me!
    Mar 2008
    554
    Quote Originally Posted by 484858444549402C0 link=1328702065/6#6 date=1328978127
    I have the impression from various threads that the appropriate time for a (double) shot of espresso varies from machine to machine - 10 seconds to 30 seconds to who knows???*
    I dont know where you are getting that information. The STARTING GUIDELINE is about 25 seconds. After that, let your palate be the guide. I have had some really fine 30-40 second extractions, but around 25 to 30 is the top of the bell curve. But ten seconds? No thank you.
    Oct 2011
    95
    help!* Im off-topic again and dont know how to move it!
    Thanks Jon! Post moved.
    David
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,355
    Quote Originally Posted by 7171617D7C7079150 link=1328702065/9#9 date=1329009388
    You cant, its a job for a Mod, suggest, copy the post, delete it, then repost where you want it to appear. :)
  1. where can I BUY a unpressurized basket for em3500?
    By youngchul76 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 28th December 2012, 02:50 PM
  2. EM3500 and pre-infusion
    By ddthiel in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th March 2012, 02:18 PM
  3. De-pressurized Via Venezia and tamper
    By ajohnc in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th August 2011, 09:18 PM
