Results 1 to 4 of 4
Thread: Newbie needing help
    Flashy
    Newbie needing help
    Hey guys,
    New to the site and though might ask for a few tips.
    Wanting to spend about $500 for either sunbeam or breville, but no idea what to look for.
    What would you guys buy, if you knew what you knew now.
    Ie, coffee machine and grinder set up recommendation?
    Thanks for reading and look forward to suggestions...
    Dec 2008
    1,036
    Re: Newbie needing help
    Hehe this question comes up a lot. Ive had a Breville 820 and sunbeam 6910 and Id go for the sunbeam over any Breville except the 900.
    I used to say the same for the sunbeam grinder but now the Breville smart grinder trumps it. Stay away from the Breville BCG 450 (grinder).
    You may or may not have luck getting the combo for $500 though.
    HTH :)
    Sep 2011
    395
    Buy the best possible grinder you can for the money you can afford, its more important to get that right, then it is for the Machine, My suggestion, Breville Smartgrinder, and either a Sunbeam EM4800/EM4820 a Breville 800 Series, or a Saeco Via Venezia
    Might tip you over the budget if you dont shop around, but youd have a fairly bulletproof setup after that, and certainly one you can improve on as your skills improve
    Flashy
    yeah, I never knew the grinder was important until I found this forum. ;D
    Will look into grinders, but looks like the Breville will be the go. =)
  1. Needing to move my Mazzer Interstate, needing a Super Jolly box
    By eves in forum General Coffee Related...
    Last Post: 11th August 2012, 09:41 AM
  2. Newbie needing grinder advice
    By meg-e in forum Grinders
    Last Post: 16th December 2006, 10:51 PM
  3. newbie needing HELP with Sunbeam EM6900
    By bucca in forum Brewing Equipment (non-machine specific)
    Last Post: 2nd March 2006, 06:03 PM
