Results 1 to 4 of 4
Thread: Gaggia coffee deluxe portafilter issues
    Mar 2012
    12
    Hi all.
    I recently cleaned my gaggia coffee deluxe group head by removing the shower screen, brew head and seal, gave it a good clean and put it all back together.
    However now when the portafilter is full of coffee (properly tamped to correct height) it wont lock in. It cant even get started As the coffee is pressed against the shower screen before the ears can get up into the head.
    Does anyone know whats wrong?
    Dec 2008
    1,048
    Re: Gaggia coffee deluxe portafilter issues
    Is it the same seal? It might not be pressed into place fully. Can you lock it in without any coffee?
    Mar 2012
    12
    Yep- locks in fine with an empty basket. And same seal...
    Dec 2008
    1,048
    if youre absolutely certain that everything that you took out went back in the same order and orientation, then it must just be sitting low.
    You could try a soft blunt object and press around the edge of the seal to see if the screen will move up further.
    Otherwise, is there any chance you trapped something under the screen?
  1. New to it all... Gaggia coffee deluxe and gaggia grinder (not sure of model)
    By kierent in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 30th April 2012, 09:20 PM
  2. GAGGIA COFFEE DELUXE
    By cuppa in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th April 2008, 09:52 AM
