Page 2 of 2 FirstFirst 12
Results 51 to 51 of 51
Like Tree1Likes
Thread: Breville BES820 issues
  1. #51
    gvl
    gvl is offline
    Jun 2018
    4
    After all I had to settle on some 70000 series food grade nickel plated brass push-in fittings made by AIGNEP for 4mm tube, 1/8 BSPP thread size. The latest catalog I got from AIGNEP lists them as 70020 00 002 and 20 bar rating but the ones I got are apparently rated to 15 bar per their eBay description, which may be a previous design. 15 bars rating vs. tired 15 bar pump, seems acceptable at least on paper, I was skeptical but they seem to hold the pressure just fine in my limited tests using very fine grind and double shot filter/button, no leaks, which left me cautiously optimistic. I had to cut the tubing and discard the brass stop ring/insert, make sure you cut as close as possible as the tubing doesn't have much length to work with.
  1. Replies: 3
    Last Post: 8th July 2013, 10:14 PM
  2. Breville BES820 & Breville BGC450 Grinder Concerns
    By martinhyson@msn.co in forum General Coffee Related...
    Last Post: 11th May 2012, 10:29 PM
  3. BES820 Issues
    By paulau in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th April 2012, 03:10 PM
