Results 1 to 6 of 6
Thread: Naked Portafiler for Breville BES820
    Apr 2012
    Florianópolis - Brazil
    8
    I'm looking for this PF but found nothing...
    Does anyone know if this PF exists, or any other company that has a PF that fits an Breville?
    tks
    Aug 2011
    Launceston
    130
    You might need to source a spare handle and have someone involved in metal fabrication cut off the bottom for you.
    Oct 2011
    1,376
    It does not exist, but it can be done...
    Apr 2012
    8
    Tks, and what about a normal PF?
    I spoke with Breville support and they said they only have the original one...
    I asked about the BES860 PF, it's look lika a Gaggia or other 58mm, but is 53mm and the 820 is 50mm... So, i'm looking for a 50mm PF from another machine to use in BES820.. anyone knows?
    Sep 2011
    395
    You could try a sunbeam PF from the 4800, or the 3800, or the 3600 their lugs are almost exactly identical to the BES820
    Failing that, you could use the PF from any of the lower end Breville units, as they also have the same lug pattern as the BES820
    There is no 'official' bottomless PF for most domestic espresso machines, Most people who have them, only do so because they produced it themselves by cutting the bottom off, It's not hard to do, Just takes 20 minutes with a 50mm holesaw
    Oct 2011
    1,376
    Like I said in the other thread, an ESP8 fits (well, it did in mine). I got mine from a Breville repair centre (they had a BES820 in for repairs to check for fit).
  1. Replies: 3
    Last Post: 8th July 2013, 10:14 PM
  2. Breville BES820 & Breville BGC450 Grinder Concerns
    By martinhyson@msn.co in forum General Coffee Related...
    Last Post: 11th May 2012, 10:29 PM
  3. BES820 goes naked (on video).
    By MrJack in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th November 2011, 11:42 PM
