Results 1 to 4 of 4
Thread: leaking steam wand - saeco magic cappuccino plus -[SOLVED]
    Sep 2010
    5
    Hi
    I was wanting to share a simple fix, but found its already covered here:
    search in this site for: saeco via venezia leaking
    Just to summarise, if the steam knob fails to turn off the steam, it could be due to the plastic cam unit having slipped on the brass steam shaft. You need to reposition the plastic cam unit and tighten the grub screw with an allen key. Follow the directions on the above post.
    Our unit is a saeco magic cappuccino plus, getting towards 10 years old. Its discontinued now.
    I pulled mine apart; if the above doesn't work I might try ordering parts from 'partsguru' ...eg Google: partsguru bsvk4
    CD
    Sep 2010
    5
    HI
    An update on this
    The simplest way to permanently fix it is to remove the internal cam knob that is attached via a screw to the brass shaft. YOu need an alan key to unscrew it. It otherwise just seems to move and require resetting, too often. I will refer to this procedure as a 'camectomy'
    Sep 2010
    5
    Hi
    The o-rings sent to me by parts guru were a tad on the small side, resulting in steam leakage around the side of the brass shaft. I got a $2.50 pack of 'Kinetic' brand assorted o-rings from Bunnings today, and it turned out that the:
    9.6 / 6.0 ie 9.6mm outside diameter / 6.0mm internal diameter rings fitted best.
    An internal diameter of *less than* 6.0 mm would have fitted better, as the fitted o-rings did feel a bit loose but once the shaft with o-rings was inserted into the barrel, the leak stopped and the steam control felt well fitted again!
    Hope this helps someone!
    Now that I have fulfilled the required minimum posts, I can post a link for the leaking venezia that I referred to in my initial post:
    http://coffeesnobs.com.au/brewing-eq...o-leaking.html
    Coffe_diva
    Mar 2014
    1
    how to remove top cover?
    Thanks for these post. I am trying to figure out how to remove the top cover of the machine. Can the black knob to regulate the steam just be pulled off?
    Quote Originally Posted by coffee_diva View Post
    Hi
    Coffe_diva
  1. Silvia Steam Wand - leaking after replacement
    By habahabanero in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th October 2010, 11:10 PM
  2. Gaggia Classic Steam Wand Leaking
    By pricespringer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th March 2010, 07:18 PM
  3. Silvia squeaky steam knob & leaking steam wand
    By Kasa in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th January 2009, 12:39 AM
  4. Saeco Via Venezia - leaking steam wand
    By steve7 in forum Brewing Equipment (non-machine specific)
    Last Post: 10th December 2007, 05:46 PM
  5. saeco magic steam wand
    By Sanford in forum Milk Froth and Bubbles
    Last Post: 4th March 2006, 09:13 PM
