Results 1 to 7 of 7
Thread: Should i fit pre-infusion chamber?? Does it make much of a difference ?
    Jul 2012
    36
    I am contemplating fitting a water hammer arrestor mod to my espresso machine so i will get a pre-infusion. Just wondering if anyone recommends it and will it make much of a difference in the espresso?
    Mar 2011
    609
    What machine do you have, and what are you hoping to achieve?
    Jul 2012
    36
    Quote Originally Posted by jamespbeasley View Post
    I have a sunbeam 4800c that i fit an opv valve and pressure gauge and it tastes so much better than the standard set-up and I am thinking of fitting this mod so the extraction will be more uniform and hopefully get a better extraction overall as almost all of the modern machines have pre-infusion so i'm thinking it must be better than not having it? Only i read one posts that said it may actually be worse, http://www.home-barista.com/espresso...ots-t1317.html depending on the type of coffee beans i use ??so not sure. I got an arrestor for cheap on ebay and i can get the pipes for cheap and it will be an easy mod to do. Just wondering if it will make a difference and will i notice anything. I'm also thinking of fitting a valve in between so i can turn it off and on at will. Can i make my machine better ??
    Have you tried with/without pre-infusion and noticed any difference ? Does it make a better more uniform extraction ? Also the arrestor looks like it creates a steady flow from the vibe pump which will also help the extraction.
    Also when i look on youtube of machines fitted with preinfusion or arrestors the extraction looks more oily and more crema forming !
    https://www.youtube.com/watch?v=EqJGe00Tuag
    Then i watched a video on the slayer and how pressure profiling can change the flavour (not saying my machine is anything like that)
    Or should i just focus on getting the grinding and tamping etc right and not worry about the pre infusion. Don't know what to do. Am i overthinking ??
    Aug 2004
    2,312
    Quote Originally Posted by karl_2020 View Post
    ........Just wondering if it will make a difference and will i notice anything. Can i make my machine better ??.......
    .......Have you tried with/without pre-infusion and noticed any difference ? Does it make a better more uniform extraction ?.......
    .......Or should i just focus on getting the grinding and tamping etc right and not worry about the pre infusion. Don't know what to do. Am i overthinking ??........
    I think not on the first two counts, and I think yes, on the last count.
    But I also think you should do whatever you want and if you subsequently think whatever you did made a positive difference, then it will have been worth it for you.
    Hope that helps.
    Jul 2012
    36
    Quote Originally Posted by Fresh_Coffee View Post
    Hope that helps.
    Thanks for the advice Fresh Coffee. It seems to be the general way of thinking from what i hear.
    Cheers !
    Jun 2011
    683
    Also, vibe pumps already produce pre-infusion of sorts by virtue of their relatively slow flow rate. Generally they take a few seconds to deliver enough water to fully saturate the puck.
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    Actually, if i may add,
    I have been playing around with a vibe pump that has pump speed control and water pressure control mods.
    I can make the ramp-up to pressure as slow or fast as I want as well as pressure profiling anytime during the shot.
    seems pre-infusion helps with some beans and makes it worse with others
    so, if you had the kind of mod you are suggesting then you would need to be able bypass it sometimes.
  1. Auber pre-infusion doesn't hold pressure, doesn't make sense
    By karl_2020 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd February 2013, 08:54 PM
  2. Full to Semi Auto Machines - Will it make a difference...??
    By cdill in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th May 2011, 09:17 PM
  3. breville grind setting didnt make a difference
    By boxta in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th July 2008, 06:53 PM
  4. Do baskets make a difference?
    By crashlee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 5th November 2007, 01:44 PM
