Results 1 to 4 of 4
Thread: 100 second shots should the OPV engage?
    Nov 2012
    31
    Still learning and greatful you guys are here to bounce things off.
    Playing with my kyocera hand mill I went 3 clicks finer. using a 19 gm load and an unpressurised basket it took 100 sec for a 60 ml shot.
    It took perhaps 30 seconds for the first drop. then 100 seconds for the double to be produced.
    I watched and was surprised to see the amount of oil on top of the shot. Not much crema and smelt /tasted overcooked.
    I had expected that the OPV valve might have been triggered but dont think it was.
    I am assuming that the chrome tube at the back left above the spill tray is the return for the OPV, is this correct.
    At any rate I will dial the grinder back 2 notched coarser and see how I go.
    BTW I have been using a cordless drill attached to the grinder at low speed to save on hand winds . works a treat.
    Mitchell
    Sep 2011
    395
    That tube isn't from the OPV, That tube is the spill tube of the three way solinoid, Basicly, it's to relieve pressure on the puck AFTER you have pulled your shot.
    Not sure if your machine has an OPV that relieves pressure from a tight grind, If it does have one, I doubt very much that it would operate the way you seem to be expecting it to be.
    May 2010
    Sydney North Shore
    1,325
    It is normal when a machine has a water tank, for the excess pressure to be released back to the tank by the OPV, while the flow from the three way valve when fitted, goes to the drip tray when flow is turned off or during a backflush.
    You should aim for about a 25 to 30 second flow for your shot by grinding coarser.
    Barry
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    If you have an OPV set near 9 bar and a 15 bar pump
    it will be working all the time
  1. 3 bar shots
    By bjeck14 in forum General Coffee Related...
    Last Post: 29th March 2011, 08:57 AM
  2. Storing Shots
    By He_Brews_Espresso in forum General Coffee Related...
    Last Post: 26th July 2010, 09:45 PM
  3. grinds in my shots...
    By Callum in forum General Coffee Related...
    Last Post: 17th June 2010, 10:04 AM
  4. Do you get grinds in your shots?
    By ahxiongko in forum Grinders
    Last Post: 15th May 2008, 04:32 PM
