Results 1 to 28 of 28
Thread: Suped-up Sunbeam (Slayer style) haha
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    this photo clearly shows the 15 bar gauge
    at the top right side is a little white knob-- (the pump speed controller)
    If you look closly at the bottom right side there is a little black lever-- (Line pressure controller)
    I can pre-infuse and ramp up or down any pressure I choose
    I can also ramp the pressure down to lengthen the shot without blonding and spend more time in the chock-let caramel phase of the shot at the end, some shots I let trickle at about 2-3 bar for a while at the end.
    It is just a cheap machine I picked up for $15 in mint cond. never used.
    the back gives easy access for mods.
    I am having a bit of fun pressure profiling different beams.[img][/img]
    I am finding that 9 bar for 30 seconds is no longer relevant
    What I do now is find the best grind for each bean,
    then adjust the machine to that grind rather then grinding for the machine.
    Jun 2012
    265
    here you can see the plumbing involved
    All the brass bits on the right were added as well as the OPV
    the copper tube leading down to the bottom left goes to the Line pressure control valve
    Jun 2012
    265
    The gauge in action
    Sep 2011
    Canberra
    24
    That is quite impressive! I ended up upgrading to a new machine, didn't think of stuffing all the extra goodies into my cafe roma! Might not have fitted either I spose. How much extra for all the bits?
    Aug 2010
    158
    Very impressive. Any room left for a PID? How do the shots compare to other machines, Silvia etc?
    Jun 2012
    265
    I chose the SB because there are plenty around cheap and the back opens up for easy access to work on.
    I picked up this one in mint cond. for $15 and all the bits were around another $130.00
    PID is not an option with a thermoblock but the temp is already stable.
    Shots are very good, I never tasted a Slivia and the Silvia will always do a better job with the milk as will all the other machines.
    I have tried the best machines at all the roasters including the "strega" and some other high end machines.
    I am not making any comparisons but I do know what good coffee is and I am making good coffee now, well most of the time anyway.
    So far my main conclusion is softer beans like a slow ramp-up to to a 9 bar peak, then a lower pressure run around 3 bar
    harder beans don't seem to respond to lower pressure profiling or even pre-infusion so much.
    i am now going to experiment with SHB (hard beans) with a higher peak pressure like 13 bar then back it down according to flow.
    Senior Member insomnispresso's Avatar
    Dec 2011
    136
    Very impressive, you are a pioneer sir!
    Jun 2012
    265
    After quite a bit of playing around with pressure profiling what I have discovered is this;
    Soft beans like a very slow ramp up to pressure that acts as a pre-infusion then after a quick 9 bar peak
    let most of the shot flow around 4-5 bar, I get great flavors out of soft beans this way.
    hard beans do not like any pre-infusion so I let the pressure build as quickly as it can (vibe pump style is slow anyway)
    I even let very hard beans extract at 13 bar for the first 15 seconds then back the pressure down to 9 bar to stop any blonding for the rest of the shot.
    this is giving me the best flavors with a very hard bean I have now.
    Normal beans, well? maybe just a straight forward 9 bar shot.
    Mar 2012
    1,276
    Is there some correlation between "Soft / Hard beans" ..and "light roast , dark roast ".. ?
    Or is this a completely different categorization. ?
    Nov 2012
    Gold Coast
    17
    Nice work C- man i opened up a brevile Cafe Roma this morning it doesnt look as if there is enough room inside. some one gave me a sunbeam EM480 i am really tempted to do this mod where did you get all the parts?
    Jun 2012
    265
    Quote Originally Posted by blend52 View Post
    Sort of yes- Softer beans are just more delicate
    Soft beans still can be roasted to any depth, however they are more sensitive and most roasters with start them on a lower heat.
    also darker roasts on softer beans tend to degrade the structure of the bean, so softer beans do like lighter roasts, darker roasts work but have a shorter life.
    I am sure there is much more to it, but that is as much as I know, Hope that helps.
    Jun 2012
    265
    Quote Originally Posted by q3rasta View Post
    Karl has a list of the parts and where he got them in this thread
    http://coffeesnobs.com.au/brewing-eq...shots-now.html
    Jun 2012
    265
    Nov 2012
    Gold Coast
    17
    Hey C-man just got the the guage & OPV from Stephanos, is it worth doing the Line pressure control valve & the pump speed controller if so where do i get them from?
    thanks Chip
    Jun 2012
    265
    thanks Chip
    not really necessary, and a lot of extra work, try it without first, but I like it for softer beans it works at treat.
    the pump speed is just a fan control/dimmer from Bunnings $36.00 (it took a few weeks to cook in) the line pressure control is a ball valve lever (needle valve would be better) from Reese plumbing supplies.
    WARNING be bloody careful with fan control/dimmers as they hold a charge and gave me one hell of a shock!
    check this out --- Pressure profiling with a cheap supercharged Sunbeam EM4800 - YouTube
    Nov 2012
    Gold Coast
    17
    hey C man did you use teflon tape or silicone to screw into the pump? I used tape it seems fine everywhere but where the opv screws into the plastic on the pump didn't feel like it was tight .
    Jun 2012
    265
    Did you cut some of the threads off the OPV before screwing into the pump?
    otherwise you can damage the pump!
    Just Teflon tape and plenty of it should do the trick.
    You will also need to drill the rivets out that support the pump or cut the rubber holder to make room to spin the OPV the repair it again to keep the pump quiet.
    Nov 2012
    Gold Coast
    17
    Yeah i cut the thread off and cut the rubber i think the plastic on the pump may be a bit stretched . On another note to adjust the pressure do you start with the valve closed pour a shot and see what the gauge reads and then adjust with the same shot or fill another basket?
    Thanks, Chip
    Jun 2012
    265
    The way I did it was to grind a fine tight puck, start with the valve about midway or wherever does not matter, start pulling a shot,
    when the gauge peaks start adjusting while the super tight shot is running or dripping or even choking, it is pretty easy to do with a screwdriver use a big cup so you have plenty of time
    you can use the same puck over and over if you need to.
    What grinder are you using?
    Nov 2012
    Gold Coast
    17
    Ive got the controversial baratza preciso
    Jun 2012
    265
    This mornings shot
    should have cleaned the dust off the machine hehehe
    Jun 2012
    265
    IDK that grinder, but looks like it should do the job ok.
  23. #23
    Jun 2012
    265
    I am able to do in my own crude cheap way what these guys are doing
    Joel Pulling Shots On His Slayer - YouTube
  24. #24
    Jun 2012
    265
    thanks Chip
    So how did you go with it?
  25. #25
    Feb 2013
    3
    But does it have 3 way valve??
  26. #26
    Jun 2012
    265
    Quote Originally Posted by coffeecherries View Post
    not sure if it does, most likely not
    either way the machine works great, I am very happy with it.
  27. #27
    Nov 2013
    1
    Hey C-man
    Firstly I thought'd I'd say that I've been very impressed with what you've done to your SB.
    I'm looking to do the same to my 4800, I'm just curious as to what the line pressure control does and where it is plumbed into.
    Also if you could give a bit of info on how you modified yours to include these two mods I'd be very happy!
  28. #28
    May 2010
    349
    Excellent modding. It would be interesting to have a machine with fully programmable pressure profiles too. Doesn't the EM4800 have a concave shower screen though? I would have thought that in of itself was a big problem.
  1. Slayer 1 group
    By Tony_Barista in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 7th January 2017, 12:12 PM
  2. Slayer Vs Synesso
    Last Post: 28th December 2012, 01:52 PM
  3. Haha - Bean Cooler Mk II
    By 22a in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 13th September 2008, 06:57 PM
