Results 1 to 3 of 3
Thread: Newbie with Gaggia Classic looking for advice
    Dec 2012
    16
    I am pretty new to this home diy coffee experience but have had the pleasure to make good coffee at work before.
    I have gone out and got myself a cheap $150 Gaggia classic as I noticed that some in this forum had suggested it as a good start point. I couldnt stretch to a silvia with my xmas money so decided it would do the trick.
    Anyway the machine I got seems to have been cleaned quite well but may need some tlc to bring it back to a good machine.
    I made my first coffee today with some pre-ground grinders brand coffee from Woolies. The pre-ground didn't taste that good but I at least got to play with the machine and check it worked ok. The machine created a bit of crema and did a good job of frothing the milk as far as I could tell ( I'm still new to this but have made quite a few coffees on work machines such as a Silvia and a Bezzera so I know a little).
    I found a few things that might be worth replacing perhaps?
    Firstly when I knocked out the coffee from the portafilter (I think that is what is is called?) the basket dropped into the bin with the coffee. I am thinking that this probably indicates that the portafilter needs a new spring to hold the basket in place? Would this be the case.
    Secondly, when giving the portafilter a clean I noticed that water didnt drain through the basket quickly at all. Would this indicate that the basket is perhaps a bit clogged and could do with a descale perhaps?
    I don't mind buying a few new parts such as the basket and portafilter spring to get the machine operating a bit better? Am I being a bit over the top or are these things normal.
    By the way as far as I can tell the machine is probably a good 10 years old and was used in a business before going to one of the employees so the parts in it are probably pretty well used.
    Thanks for any help. I will check the forum for some info to other general questions I have. Thanks for your time.
    Jan 2012
    50
    Quote Originally Posted by Penguin740 View Post
    Just to clarify, is the filter basket pressurized or normal? Does it have plenty of holes on the underside or only one?
    http://coffeesnobs.com.au/Attachments/P1010668.jpg - the bottom filter baskets are non-pressurized.
    If the baskets were pressurized, then yes, the water would drain through quite slowly.
    If they are normal then you might just need to give them a good clean. I've never had scale build up on the filter baskets but you do tend to get fine enough coffee grinds stuck in the holes.
    Dec 2012
    16
    Re: Newbie with Gaggia Classic looking for advice
    The basket is non-pressurised as it has a lot of holes. I'll give it a good clean and then soak in coffee clean. Thanks for the help and also photos to explain the difference between pressure and non pressurised baskets.
    I am thinking of replacing the group head seal as I assume these perish in the heat over time.
  1. Newbie to Gaggia Classic - brewing problems
    By KimDD in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th September 2011, 06:33 AM
  2. need advice re Gaggia Classic
    By dodoman in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th October 2010, 07:57 PM
  3. Gaggia Classic - newbie near clear coffee
    By catch-22 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th March 2009, 01:36 PM
  4. newbie joins the path to enlightenment with a Gaggia Classic
    By cyn7180 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd February 2009, 03:13 AM
  5. Gaggia Classic Newbie
    By Sandman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th January 2009, 05:32 PM
