Results 1 to 2 of 2
Thread: Broken water tank - advice please
    Nov 2009
    2
    Unhappy Broken water tank - advice please
    Hi all - I acquired a Sunbeam EM5800 from the 'pay it forward' forum (many thanks ausfitter!), and unfortunately the nozzle at the bottom of its water tank is broken (possibly in the unpacking process). So I can't use it, as it just leaks water out as soon as you put the tank onto the machine. It can't be glued back together as the pieces are too small. Can this be fixed, even by gluing the whole thing onto the machine, or by gluing some other kind of tube onto it (plastic welding even?), or do I just have to buy a new tank. Can you get a new tank for this machine? Bear in mind that the machine was free (I just paid postage) so I don't want to spend a fortune. It would be so nice if someone had one...
    Feb 2013
    3
  1. cleaning water tank and water carrying tubes of Rancilio Silvia from "gunk" ?
    By acid_rider in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2012, 11:24 PM
  2. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 04:16 PM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 10:43 PM
  4. Levetta water tank
    By MarkC77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th February 2008, 09:03 AM
Tags for this Thread
