Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Jimmytheboot
Thread: Gaggia Classic - somewhere to get mods done?
    May 2013
    2
    I have a GC made in 2007, bought new in 2008. Followed the advice here and replaced the steaming wand when it was new. No matter what I do with the grind (Solis grinder) and now matter how fresh the beans the pour is too quick and always has been. I've become used to the taste but I'd like to get this sorted so that I get a much better coffee. My thinking is that the mods described in this forum are probably the next things to try but I am not in the least bit handy and I don't have many tools. Wondering if the companies that service the machines will also do a diagnosis and make appropriate mods. I'd be looking for somewhere in inner city Melbourne. Any tips?
    Senior Member deegee's Avatar
    Sep 2012
    Brisbane Southside
    349
    I would suggest you try here The Coffee Machinist Rick is a CS site sponsor. He is in Melbourne - not sure exactly where.
    I have not dealt with him personally, but judging from what I have seen here, he is a great coffee tech, and modder extraordinaire.
    Cheers, Deegee.
    Mar 2013
    1,281
    Using pressurized (dual-wall) baskets? Swap them out for nonpressurised (single-wall).
    If that isn't the problem, then it's your grinder. There is nothing on the Classic that requires modding to pull good shots.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    Sounds like the grind is not fine enough
    Recalibration looks a little fiddly with the case clips etc but wouldnt take long, assuming you have a solis (baratza) maestro...
    How To Re-Calibrate a Baratza Grinder - YouTube
    Dragunov21 likes this.
    May 2013
    2
    Thank you for all these great responses. Coffee Machinist looks perfect, and a useful contact to have. Will start with trying to improve the grind.
    Dec 2010
    395
    I didn't think there were any mods that would slow down a pour.
    Mar 2012
    Bathurst
    1,157
    Quote Originally Posted by Hildy View Post
    Over pressure valve? If the machine chokes when increasing the grind fineness, grind volume or tamp pressure, installing an OPV will relieve the choke pressure and let the 9-10 bar or whatever's set flow through the grind while dumping the excess.
    It's what I did to my BES820 as it was choking a lot when I was fiddling with finer grind and harder tamps. I could then tamp as hard as I want and grind as fine as I could and it still wouldnt choke, however it took forever to get a shot out of it (I didnt do that often).
    The classic already has an OPV though as far as I know so perhaps adjustment or preinfusion or something.
    Coffee Newbie okitoki's Avatar
    May 2013
    Perth. WA
    454
    big difference in getting a better grinder...
    My initial shots from using the Sunbeam and Breville was fast... say 10-13secs from power on in my Silvia... let say the taste of the coffee was pretty bad... even when I tamp them really hard.... using a weighing machine, I was probably doing 20KG press down and still get fast shots
    Now I have a Macap grinder, it gave really fluffy grinds, and tamping it was not hard at all... So far my shots have moved up to low 20s seconds, and the crema is noticably better and taste is much much better than before... still need to fine tune my grinder at the moment, but have a better grinder can really make a whole lot of difference (yes, I was also sceptical in the beginning about how important a good grinder is)
    Nov 2008
    56
    Don't Gaggia Classics all have OPV? My work Gaggia Baby (new 1992+), basically a plastic version of the Gaggia Classic has one. Are you sure that the mod is not simply an adjustment of the OPV to the correct pressure?
    Mar 2013
    1,281
    Yep.
    Tenchars
    Jun 2013
    33
    I had the same problems, however IMO the only modding needed on Gaggia Classics is the steaming arm (for when people want milk based drinks) and an unpreassurized basket. This, coupled with a decent grinder will give you fantastic shots of coffee. My machine is now pulling 25-27 second shots that taste fantastic.
  1. New (Second hand) Gaggia Classic for a very very low price....Advice on mods?
    By Colen001 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 21st April 2013, 10:42 PM
  2. Gaggia Classic + mods
    By mazzanet in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd January 2009, 07:47 PM
  3. mods to gaggia classic
    By talbashan in forum Brewing Equipment (non-machine specific)
    Last Post: 28th October 2006, 11:41 AM
