Results 1 to 5 of 5
Thread: EM6910 not working....
    Apr 2012
    42
    My EM6910 is non functional...
    Switched on warmed up makes all the sounds of a pump working but no water or steam...
    Any ideas anyone ???
    May 2013
    Perth, Western Australia, Australia
    11
    Hi Rooeey.
    Check that the straw that draws the water out of the reservoir is actually going down when you slide the water tray back in. It can sometimes get caught up.
    Hope this helps
    Daz
    May 2009
    Bendigo
    1,029
    Hm... might be the magnet in the water tank, but I don't know if you'd be hearing sounds at all if that wasn't working/in palce.
    Will just go try mine...
    There isn't any straw for water in the 6910 - the water is taken through a valve in the base of the water tank
    May 2009
    Bendigo
    1,029
    Nope, it isn't the magnet - removing it gave me the beeps but I still got water through both grouphead and steam wand.
    Is your water tank properly seated? When you put it in, there is a final 'clunk' feel when it moves the last tiny bit to engage the valve and then to get it out you have to put your fingers in the hole and lift it slightly for it to move. Maybe you haven't pushed it in hard enough?
    Feb 2010
    Brisbane southside
    91
    Perform a factory reset. When I tried changing the settings on one it did what you describe.
    I know you haven't changed anything but it take less than a minute and may work for you.
  1. Em6910 (might be em 6900), steam no longer working
    By talism in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th March 2015, 06:54 PM
  2. !!!GONE!!! - Sunbeam EM6910 - working - Bunbury WA
    By Cooper69S in forum Paid Forward - Taken
    Last Post: 7th January 2012, 11:25 PM
  3. Hi all, Just acquired an almost working EM6910
    By Georgea in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd May 2011, 01:05 PM
