Results 1 to 8 of 8
Thread: How to power up a PID in Gaggia Classic
    Jun 2013
    3
    I am having difficulty powering up my PID. The wire I am supposed to tap from is hot when the power switch is off and turns off when the power switch is turned on.
    > My gaggia classic is from 08/2012 and the wire I am tapping is white I am following the direction from here: up.picr.de/3043530.pdf ; I followed the exact instructions. I would like to turn the PID on, whenever I turn the espresso machine on. Thank you for any help.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    Instructions say to tap a blue wire for classics made after 2006
    Mar 2013
    1,281
    Should be the blue one on the far right, second from the top (looking from the back of the switch panel), IIRC.
    If I recall the wiring of active/earth is arse-about at the IEC connector so make sure you're piggybacking it to the right one (not to the incoming active again)
    Go to Jaycar and buy a $10 multimeter; it will be invaluable. Find the terminals that have 240 between them when the switch is on and nothing when the switch is off.
    If you still can't figure it out after that let me know and I'll pull the top off mine and take some photos.
    Dec 2010
    395
    Quote Originally Posted by Sindibad View Post
    That suggests it's a lowside switch. What are you hooking that wire to? (probably hook it to the neutral lead.)
    Mar 2013
    1,281
    Quote Originally Posted by Hildy View Post
    No, it really doesn't.
    Jun 2013
    3
    Thank you for your suggestions, so far no luck, the color does not match. As I said the wires are white not blue on my 2012 US model. When I connect the PID It is always on when the machine is off when I turn it on the PID is off. I am lost. Any idea what is wrong?
    Mar 2013
    1,281
    Sounds like you have the PID active connected to the normally-closed contact (closed when the switch is "off") rather than the normally open (closes when the switch is flicked "on").
    Do you have a multimeter?
    *EDIT* US model? Is it rated for 220V or 110V?
    Sep 2013
    Melbourne, Victoria, Australia, Australia
    13
    Just a thought, is the case or enclosure of your PID metal? If it is, you may want to consider using an AC/DC adaptor between the Gaggia power and the PID.
    The PID should be able to run off a 12V DC adaptor. Just check the specs of your PID. It's much safer than running live 240/110v to a diy box.
  1. Gaggia Classic steam losing power
    By patanab in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th March 2016, 11:28 PM
  2. Replies: 6
    Last Post: 15th March 2012, 09:20 PM
  3. Gaggia Classic portafilter and GAGGIA PROTEO ROMANZA
    By cazby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th October 2011, 06:50 PM
  4. Gaggia Classic power switch
    By c.beans in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th February 2011, 09:25 AM
