Results 1 to 10 of 10
Thread: Persistently leaking Krups Vivo
    Apr 2007
    21
    I have an old Krups Vivo which I wish to relegate to office use (replaced by Silvia at home). *However, it has continued to leak at the group head despite a fresh rubber seal. *:-X
    The repairman reckoned it needed a new grouphead ($150 including labour costs) and blamed it on inadequate cleaning. *He charged me a non-refundable $39 to tell me this. * *:o
    However, I never overfilled the basket, always flushed the showerscreen after use, removed the seal and complete wipe down the group headevery couple weeks, descaled quaterly and always used filtered water. * This for a one cup a day use. *::)
    DO I really need to replace the grouphead? *I heard that some people can improvise a shim to build up a worn grouphead. *Can someone explain what materials they use, where to put it and cut it to size.
    Nov 2006
    1,673
    Re: Persistently leaking Krups Vivo
    Maybe you can just bin it and put the $150.00 towards something else. I very rarely say this but Krups=kraps. (sorry)
    3,498
    Quote Originally Posted by lucinda link=1175850580/0#1 date=1175916469
    Yep, unfortunately have to agree with you on that.
    But if you really must try and fix it (they are probably the best of the Krups range - although that doesnt say much)......
    On commercial machines, spacers are used behind the group seal. There are two different types of material... about 1mm or greater they use neoprene..... and for the 0.30-0.80mm spacers it is a paper (stiff cardboard) like material similar to that used for water seals in car engines- probably available in sheets from auto shops.
    Both these materials could be cut with a sharp scalpel to the size of the group seal, and the resultant washer installed immediately above the group seal.
    Before making the effort, check in the area where the group seal fits if there is much corrosion. If the surface is very uneven, even a spacer might not help.
    Good luck if you decide to go down this path.
    Apr 2007
    21
    Quote Originally Posted by JavaB link=1175850580/0#2 date=1175917177
    Thanks Lucinda,
    I dismantled the entire unit just to see what kind of condition it was in. I am not convinced that the repairman was correct about corrosion. There appears to be no significant evidence of this. Do you think he was trying to overservice me?
    Image resized to aid viewing, 640x480 pixels is the largest practical size to use.....
    Apr 2007
    21
    Instead I prised this bit of plastic from the rim which seemed in sore need of replacement. Do you know where I can get one of these
    Image resized as per above.....
    Nov 2006
    1,673
    I suppose it depends on how many coffees you make per day at the office. If you just want something that is small and takes up very little room yet still pushes out a good coffee one or two times a day than you could consider a Gaggia Cubika. The baby brother to the Classic.
    The problem with the Krups could be anything and spending $150 may be more than the machine is really worth, considering that the issue may not be solved, especially when a cubika costs anything from $265 - $300 which is what the price is when I googled it.
    The cubika does have an aluminium boiler, though for something that is just for the office that you do not want to spend a fortune on it could be your best bet.
    Apr 2007
    21
    Quote Originally Posted by lucinda link=1175850580/0#5 date=1176090549
    You might have missed it but Krups got replaced by a Silvia last month. However, I thought I could squeeze a bit more use from my old machine if I did a cheaper DIY job.
    Nov 2006
    1,673
    I didnt miss it, I was thinking of your comments of the krups being an office machine and a suitable replacement for that size machine for the environment you were thinking of putting the krups into.
    Feb 2005
    2,601
    Ive often used that make-your-own gasket material JavaB mentioned
    ( always on car engines, never on coffee machines. That should not be an issue because it will sit under the group seal and therefore not come into contact with your brewing water)
    It comes in various thicknesses and very easy to cut with a blade or even scissors. Id get a small sheet of that, trace a couple of outlines using your group seal as a template, and stack as many as it takes to get a proper seal.
    If that doesnt work it wont have cost much to find out. If it does, and it should providing there is no distortion on the group itself, it will be a cheap fix.
    -Robusto
    Apr 2007
    21
    Quote Originally Posted by robusto link=1175850580/0#8 date=1176104365
    Ive often used that make-your-own gasket material JavaB mentioned * *
    It comes in various thicknesses and very easy to cut with a blade or even scissors. *Id get a small sheet of that, trace a couple of outlines using your group seal as a template, and stack as many as it takes to get a proper seal.
    -Robusto
    Thanks for all the advice. *I am going to try a multi-pronged approached. *I am trying some red fibre washers to place between the group head and rubber gasket and alsousing Selleys 401 Silicone (food safe/heat resistant) where the worn plastic inserts were located. *I let you know how it all goes.
  1. Krups 988 leaking - help please!
    By yuna0108 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd January 2012, 01:04 PM
  2. Krups 4050 leaking
    By Nuova in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th September 2010, 09:15 PM
  3. Is it worth upgrading to EM 6910 from Krups Vivo?
    By viktor in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st February 2008, 10:51 PM
