Results 1 to 27 of 27
Like Tree4Likes
  • 1 Post By colonelfeline
  • 2 Post By Dimal
  • 1 Post By timdimdom
Thread: Breville, Sunbeam or something better?
    May 2014
    13
    Hey guys
    Looking to buy a low-midrange coffee machine for home. Less than $400 preferably.
    We have a cheap Sunbeam at work that is pretty reliable, doesn't do an amazing job obviously.
    I'm looking at getting a Breville for home, maybe the Breville 800 model. What are your guys' thoughts on that? Mainly using for espresso, machiatto and the occasional latte.
    Thanks!
    LexiconDevil likes this.
    May 2014
    13
    Also,
    What are your opinions on the DeLonghi machines, specifically the ECO310?
    Thanks in advance!
    Senior Member coffeechris's Avatar
    Jul 2011
    771
    Hi and welcome.
    Have you considered a second hand machine? For $400 you may get something brand new that will do a similar job to what you already have. If you however look at something second hand you could get your hands on something like a Rancilio Silvia. I only say maybe. On top of this like most will suggest on here is that you will need to consider a grinder as well. You can by a great machine, however if you only by a cheaper grinder or use ground coffee you cant really expect to much. A grinder is more important.
    Kind regards,
    Apr 2012
    WA, perth
    247
    the eco series will be in the same league as the cheap sunbeam you have. main things you want to look for is something with:
    1. non pressurised baskets
    2. an OPV valve.
    the 6910 goes for 150-400 on gumtree. if not, you're going to have to mod a machine to remove the pressurised baskets. (any of them will do in this case)
    next thing is a on-demand conical burr grinder. minimum will be a sunbeam em0450?
    without an on-demand grinder there wouldnt be much of a point upgrading
    just my 2 cents
    17,415
    Personally, if I was on a limited budget (and I have been on occasions), I'd opt for an AeroPress and use the rest of my funds to purchase the best Grinder I could. That way, you get to enjoy wonderful coffee from the AeroPress and if funds permit in the future, buy a decent quality small Italian/Spanish espresso machine. You can keep the AeroPress then for use at work or when away from home...
    Apr 2012
    WA, perth
    247
    or even find some single walled baskets and use the sunbeam that's already there with the new grinder
    Dimal likes this.
    May 2014
    13
    Hey guys,
    Thanks so much for the replies!
    Where would I find single walled baskets?
    It looks like I might go for a nice grinder (any recommendations around the $200 mark?) and a cheap Sunbeam/Breville machine until I can get my hands on a really nice piece of equipment.
    Does that sound like a plan?
    And also, what would higher quality espresso machines should I look for down the line? The Rancilio Silvia? Any other recommendations?
    Thanks again
    May 2009
    Bendigo
    1,029
    Most SB machines, even on gumtree/ebay will come with both double and single floor baskets. Or check on ebay for parts.
    What coffee do you like or expect to be making? If milk varieties in any number (i.e. other than once every so often) look for double boiler or double thermoblocks - the steps involved in getting a single boiler to perform for both coffee AND steam will get old very fast.
    The SB twin thermoblock and Breville double boiler have a much simpler use and the SB can keep producing coffees for a houseful of drinkers. The most I have done at one time was 7 and the last coffee was as good as the first. Machines with single or small boilers have to keep waiting for the boiler to refill or build up pressure after each use - thermoblocks just keep pumping through the water and steam - it's like using a pro machine and producing coffee and milk simultaneously.
    If the SB at work isn't producing good coffee it's because it isn't being used or maintained properly. Or people haven't learned to make coffee properly - there's more to it on any machine than cramming coffee into a basket and running water through it. My SB (and those of many others on here) produces excellent coffee, very simply and reliably. I haven't used the Breville range but there are threads here dedicated to them so have a read.
    I'd recommend the SB EM6910 along with some reading on CS to see what process to use and for tips on getting the best from it. For a start they are a lot less to buy than the Brevilles which leaves more for the grinder. If you're buying online, try to make sure you get to see the machine in action, or maybe pay by Paypal so if it is non-functional you can get your money back.
    For grinders, the SB EM0450 would be the minimum, but I'd say go for at least the EM0480 - they are very similar but that switch on the side of the 480 is a very useful addition. The SB grinders are very good for the price and the only thing normally needed is to ensure it is shimmed correctly. (some of them will not grind fine enough for espresso so some shims (thin washers) get added under the bottom burr to get it in the right range)
    You will often see the 2nd hand SB's come with the grinder so maybe look for one of those deals. e.g. a fairly new 6910 and 480 were sold on ebay 2 days ago for $305 along with all you'd need except beans.
    Apr 2012
    WA, perth
    247
    Quote Originally Posted by colonelfeline View Post
    Hey guys,
    Thanks again
    $200 mark grinder, if you can stretch it a little, try the breville Smart Grinder. myer has a one for one deal at the moment
    if not, journeyman's suggestion for a 2nd hand 6910 is very highly recommended. just make sure the seller used filtered water and backflushed it regularly. and watch them pull a shot before you buy to make sure the opv is in working order (pressure gague will be working and pf wont blow out during shot)
    for single walled baskets, you might have to try using a dremel tool to remove the outer wall, or there are some charitable peeps on CS who will do it for you so long as you cover postage. youtube will be helpful with how to do it if you go down that route =p
    out of curiosity, what sunbeam are you using at the moment?
    May 2014
    13
    Thanks for the replies
    Using Sunbeam Cafe Espresso at the moment - there's not too much we can tinker with on it, it's a pretty basic unit.
    I like espresso's, will make the odd cappuccino or machiatto with it as well, but definitely won't be making multiple milk coffees.
    I see there are some deals for the EM6910 espresso machine + EM0440 grinder at around $450-$500 brand new. Do you think this would be a good starting point?
    May 2009
    Bendigo
    1,029
    I'd talk to them about upgrading the 440 to a 480. Better grinder for very little more. With the 480 it would be a good starting point and there's a lot of info on CS re using them.
    If it's mainly espressos, the issues re single boiler machines may not be a concern for you. To me the idea of following the necessary rigmarole for virtually every coffee is a definite deal breaker but mostly the missus and I (& friends) drink milk-type coffees.
    May 2014
    13
    Great, thanks!
    I've done a bit of searching - I've found a brand new 480 grinder for $100, or a second-hand Gino Rossi CC45 for $150
    Should I go for the CC45??
    Aug 2013
    11
    if the work machine is the sunbeam cafe creme II I had that & replaced it (after 3000 cups) with the breville 800 today.
    it makes coffee from beans and to me even the shittest machine is better than a jug & international roast.just a bit easier to use than the 'beam really push buttons nice handle to turn front load water I can see the first cup being an easier proposition now.
    and the cup height clearance is perfect every cup in the place fits under it nicely
    for $279-299 at the moment i'd tell anyone to spend the extra 100 on one of these or even the next model up.we had to bypass that and opted for the simplest easiest "less likely to mess it up" one for Joe Public to use ....
    May 2009
    Bendigo
    1,029
    Great, thanks!
    The Gino is a commercial grinder - to be that price you'd have to ask what is wrong with it. Buying it cheap may not be so once you've paid for worn parts etc. Also I think it's a doser - most CS'ers seem to prefer doserless - wastes less coffee. I'd probably go the brand new one - at least there's a warranty with it.
    May 2014
    2
    If you don't mind me asking, but where did you find this?!
    Apr 2012
    WA, perth
    247
    id head towards the 6910 if i were in your position. like journeyman said, the 480 is a big step up from the 450 for only a little more. maybe if you can find somewhere that sells the 6910 with 480 within your budget? or settle for a second hand set?
    Dec 2010
    395
    How is a 480 a big step up from a 450?
    May 2014
    13
    Quote Originally Posted by reiimondo View Post
    found it online from a private seller, but haven't got a reply yet
    do you think a 1-2 year old 6910 will be reliable?
    would you guys go the 6910 over the breville 800 series?
    ta!
    May 2014
    13
    Quote Originally Posted by timdimdom View Post
    that sounds like a good plan
    May 2009
    Bendigo
    1,029
    If maintained properly a 2nd hand 6910 and 480 should last a long time. And if not, there is a wealth of info on here on how to iron out the bugs. Just make sure it is working - it can be a PITA trying to diagnose a machine that doesn't start. Pretty much the only thing that normally goes wrong with the 480 is many of them need to be shimmed to give a fine enough grind in the middle of the 25 position scale. (so you can adjust up or down depending on beans)
    Whereabouts are you? I'll be selling a complete system in the next couple of days. I'm heading to Melb today to get my EM7000 which comes with everything so my 6910 and all the spares etc will be on here within a day or so. Just buy beans...
    May 2014
    13
    Hey Journeyman
    I'm in Sydney, but can easily organise a courier pickup through work
    Any idea of prices?
    Senior Member Bosco_Lever's Avatar
    May 2009
    QLD
    444
    Great, thanks!
    The Gino Rossi CC45 is a well built commercial grinder and will last longer than any of the appliance grinders. New they retail for $700 plus. There are a tonne of them out in the wild and you can pick up really good ones for between $300-400 with minimal wear and still looking good. I picked up a RR65 without a hopper for $250 and it has never missed a beat. I use it for plunger and pourover duties now, though it worked great for espresso for a couple of years. It was from a restaurant that closed down and has seen some wear. The Burrs did not need changing. Condition overall was fair. To me it was a bargain.
    If the one for $150 works, and looks ok, then I would buy that over any other grinder. Second hand they represent the best value on the market for a grinder as they are a commercial unit, built to last.
    Doser or doserless is irrelevant if you are on a budget and want value for money. You want a unit that can grind coffee. A few sweeps with a brush and a dosing chamber is clean. It is all about technique.
    Any comments about new grinders $500 and under, being superior to a 2nd hand working GR are just internet speculation. I have used these grinders and so have many others. They are good units and highly under rated.
    Main disadvantage is their size, when it comes to home use. In the coffee scene, you will be surprised how may units are still being used in low volume venues.
  23. #23
    May 2014
    13
    Hey Bosco,
    Thanks for that reply!
    There might be some extra costs involved with replacing some pieces (it is a fairly well-used model from an ex-cafe), so if I can get the grinder to me for under $200, I might go ahead with that!
    I've found a place that sells factory 2nd Sunbeam 0480's for $119, so that will be the back-up plan
    Cheers!
  24. #24
    Dec 2013
    11
    Have you thought of lelit combi? I just purchased one and it looks like a well built machine with built in grinder (of decent quality). This is my first real machine, coming from nespresso and i only made two cups so far and both were pretty decent, and it can only get better.
    The one i got is an older model and it cost me 685 including courier shipping. Very happy with the purchase.
  25. #25
    Apr 2012
    WA, perth
    247
    Quote Originally Posted by Hildy View Post
    the 480 has an overall sturdier construction with much more metal bits than plastic and also has more grind settings. TBH i havent really played with the 450, but from using the 480, it seems to be at the bare minimum i would put up with - so by extrapolation i personally would shy away from the 450.
    i see your point on being just a small step vs a big one, but considering longevity i'm very weary of the 450 and have seen many posts here on the 480 lasting years of use.
  26. #26
    Mar 2011
    609
    Only differences between the 450 and 480 are cosmetic. Same burrs, carriers, even grind settings. The metal bits on the 480 are cosmetic only.
    The 450 is no longer a current sunbeam model though (not listed on their website anymore), so you might be able to find it at a discount. If you don't mind the plasticy look, it's more bang for your buck than the 480
  27. #27
    May 2009
    Bendigo
    1,029
    My 450 and current-use 480 are both very good machines. Apart from the shim issue, the other thing I found with another 480 I have is the spindle has side play. I'm planning on doing Ray_C's adjustments to it to see if I can make a decent grinder out of it - grinds OK for now but both the others do a better job by taste in the cup.
    And both the others have zero play in the spindle - not sure why the other one has it yet.
    But yes, they are very similar machines and parts seem interchangeable. There is a switch on the side of the 480's that I find useful - I prefer the 2-handed operation using the side switch although both machines have the PF-push switch - it's a decent alternative particularly when using the PF holder that clips onto them. I take those off as my preference is more 'hands-on' so to speak.
