Results 1 to 11 of 11
Thread: No Steam Presssure on Gaggia Cubika
    Feb 2007
    51
    Hi Coffee Snobs,
    Ive recently "washed" my Gaggia Cubika, which involved placing it my large kitchen sink upside down and basically washing it down with water (not sure if it really did much). Anyway after that Ive noticed that im not getting much pressure at all out of the steamer wand. Any ideas on what i can do to fix this?
    Feb 2005
    2,601
    Re: No Steam Presssure on Gaggia Cubika
    You placed an electrical appliance in a sink and washed it with water?
    Hmmmm.
    -Robusto
    Jun 2006
    754
    Did the manual say something like "do not immerse this applicance in water"? Thats what i find on most manuals.
    Feb 2005
    2,601
    I think the mere presence of a power cord automatically says that.
    -Robusto
    10,496
    nicholasm dont let them scare you off.
    Does the machine still work normally other than the steam problem?
    Feb 2007
    51
    i actually didnt wash it in water, i ligthtly sprayed the part where the water comes out of the head with water.
    anybody else whod like to post a smart a response makes me wonder who would bother trying to be funny on the internet. if that makes you feel better heres a clap from me
    Feb 2005
    2,601
    Ah, Nicholasm, as Thundergod says, dont let us scare you off! We all need thickish skin sometimes.
    But back to your steaming problem. Is the brew water hot enough, normal temperature? So the element is heating normally....
    Has it been descaled? Scale can build up around the element to the extent that its insulated from the water and wont heat properly.
    Assuming scale is not the problem, run about 200 mls of water through the group to ensure the boiler is well and truly full, then see how it steams.
    -RObusto
    Feb 2007
    51
    ah thanks a million robusto, not a problem about the comments!
    Normally i do run about a cup full of water through the group head.
    Do you have any recommendations on what type of descaler to use on the cubika? I heard that there are certain types i shouldnt use because of the make of the cubika (aliminium portafilter or something like that!)
    Feb 2005
    2,601
    I can only advise you NOT to use citric acid. Its great for copper and brass boilers, but corrosive on aluminium boilers.
    But again, is your water coming out very very from the group? If it isnt, that may indicate the element cant heat enough to produce steam.
    Try that first.
    -Robusto
    Nov 2006
    1,673
    cafetto makes a good espresso cleaner for gaggia machines. Any good coffee shop should have it, otherwise you can get it from coffeeparts (site sponsor)
    Sep 2006
    Sydney Straya
    144
    Hi Nicholasm
    Unfortunately I am unable to provide constructive advice re your problem however, as a fellow Cubika owner, I have to ask, have you had the "machine" long?
    The reason I ask is that in the 7 montrhs I have endured my "machine", the power switch has failed (bypassed rather than paying 40 bux for another). As well as that, the steamer switch has also failed necessitating the application of a satay stick to keep the switch in so I can get steam for frothing.
    Added to that, it seems very underpowered especiall in the task of providing steam for milk frothing, and, as I expressed elsewhere in this forum, the only thing preventing me from placing it upon my driveway and making (almost) inaudible keening noises while I drive my car over it is the fact that, as yet, I am unable to afford a decent machine (note machine, not "machine" as used in describing the cubika).
    Also, knowing my luck, I would probably do a tyre while I did it thus incurring a replacement cost far greater than the Cubika is worth.
    I find it interesting that it is very hard to find a promo for the Cubika on most of the web pages on Gaggia products.
    I feel your pain.
    cheers
    jeff
  1. problems with Gaggia Cubika.....
    By thegeneral74 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th August 2009, 11:24 AM
  2. Gaggia cubika
    By derrilex in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 14th August 2009, 06:56 PM
  3. Any Info on Gaggia Cubika?
    By Boostbus in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th October 2008, 10:32 AM
  4. Gaggia Cubika, 10 months old
    By nicholasm in forum SOLD
    Last Post: 29th September 2007, 10:05 AM
