Results 1 to 30 of 30
Like Tree12Likes
  • 2 Post By TC
  • 2 Post By TC
  • 1 Post By deegee
  • 2 Post By Dimal
  • 3 Post By burr
  • 2 Post By sprezzatura
Thread: Gaggia Classic Cloudy Water
    Jan 2015
    18
    Hello everyone,
    I have Gaggia classic less than 1 year old, I read different opinions about descaling it with citric acid. However I did use it to descale my machine,
    and now the water is cloudy with some white pieces in it, not matter how many tanks I flush away! I don't believe the brew head is dirty my machine is quite new!
    I changed the water, did everything I could. however the water from the milk frothed is not as cloudy.. it's almost clear.
    Anyone knows how to solve this? please not that no pro. near by. So I can't take it to someone and fix it.
    14,666
    Hello Sarah,
    How did you decide that it needed descaling? Acid + metal = ??
    Citric acid is not an accepted descaler for anything other than espresso machine parts in a bucket. It can and does cause damage to aluminium boilers, solenoids, gicleurs and it's a definite no go for HX/Dual boiler machines.
    How to solve it? Flush a heap and hope you haven't done too much damage.
    It's always a good idea to be sceptical of what you read on the internerd. Way too much of it is rubbish!
    Dimal and GreenBeanGenii like this.
    Jan 2015
    18
    yeah but I read so many people said that they use it and never had any problem with it. Too bad, I guess the machine is damaged now..
    Thanks for responding
    Jan 2014
    Discovery Bay, HK
    269
    Hi Sarah26! What is your maintenance routine for your Gaggia Classic? Do you backflush? Have you tried removing the shower screen and dispersion plate and cleaning them manually? You seem to suggest that the water coming out of the frother is cleaner than the water from the group head. Do the cloudy water eventually clear up when cooled?
    Jan 2015
    18
    Hi JojoS,
    Well no it doesn't clear up, the shower screen looks shiny and clean as I said I've been using it for less than a year. I tried unscrewing the shower screen but its STUCK no matter how hard I try. Would you suggest I back flush?
    Senior Member deegee's Avatar
    Sep 2012
    Brisbane Southside
    349
    Quote Originally Posted by Sarah26 View Post
    Hello Sarah, I doubt that you have seriously or permanently damaged your Gaggia. Citric acid is a relatively mild organic acid and is in fact used in numerous proprietary de-scalers. One very well known brand contains 60% citric acid.
    The cloudy water is probably dissolved scale and the white pieces are bits of scale. Just keep flushing until the water runs clear.
    Jan 2015
    18
    Hi Deegee,
    That's what I thought, but I flushed around 10 tanks now, would it take that much? should I try back flushing?
    14,666
    Quote Originally Posted by deegee View Post
    Citric acid is a relatively mild organic acid and is in fact used in numerous proprietary de-scalers. One very well known brand contains 60% citric acid....
    Yes- the other components are used to break up plaques of scale that those who use it neat find fouling solenoids, gicleurs etc.
    We pick up the pieces frequently and I can assure you that 40% matters.
    Jan 2014
    Discovery Bay, HK
    269
    Hi JojoS,
    I suggest you remove both shower screen (#2 Phillips head screw driver) and the dispersion plate (5mm Allen wrench) before you do anymore flushing.You can remove the water reservoir and put the Gaggia Classic on it's back for better access to remove the 2 parts. As pointed out by others, what you see in the water are bits of scale. What type of water do you use? Are you in a hard water area?
    Sep 2012
    Brisbane Southside
    349
    Hi Deegee, That's what I thought, but I flushed around 10 tanks now, would it take that much? should I try back flushing?
    That's puzzling, 10 tanks is a lot of flushing, and I would have thought that would be more than enough to remove all the citric acid and dissolved / loose scale from your machine. I also wonder why the water from the steam wand is relatively clear, it's taken from a bit higher in the boiler than the water that goes through the brew head, but not much.
    There is a slight risk in doing a back flush while there are still some solid pieces of scale in the system. They could block the passage in the brew head, or the solenoid valve. I don't think that it is likely to solve the problem anyway, so probably better not to, though if the water was just cloudy with no solid bits, it would be OK .
    Are you allowing the water to heat up in the boiler before flushing, or just pumping cool water through the boiler without bringing the machine up to brewing temperature ?. To be honest, I don't know if that would make much difference, but it could be worth trying. It may be that the boiler needs to be heated then cooled a few times to help remove all the scale that has been loosened but not fully dissolved by the citric acid.
    burr likes this.
    Jan 2014
    Discovery Bay, HK
    269
    If the cloudy water is more severe from the group head than from the steam wand, it is likely that the space between the boiler base and dispersion plate and the space between the dispersion plate and inner side of the shower screen is coated with scale. Best to do manual cleaning on this 2 parts as well as the base of the group head. Do not backflush until then as it can just mess up your 3 way Solenoid.
    Jan 2015
    18
    Thanks everyone, I will do so and hope it works.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    Hi Sarah,
    Here's what the inside of your Classic probably looks like (image of a Via Venezia I was working on that was not de scaled nor was softened water used in the tank - very similar to the Classic boiler in water flow respect).
    Please note the upright copper tube in the centre of the boiler: when you press the button to extract espresso and the pump starts it forces water into the boiler which displaces the hot water which flows down that tube.
    You can see how challenging it is to flush the scale out which like to sit on the bottom of the boiler!
    So ... lots and lots of flushing.ImageUploadedByTapatalk1441030123.759860.jpg
    Dec 2013
    Toogoom, QLD
    931
    Oops! My bad - that's actually a Gaggia Classic boiler I serviced (I just throw the VV's away now ... so that's what yours looks like inside I'm guessing.
    Jan 2015
    18
    oh, now I just wanna open it, out of curiosity. I couldn't find the right screwdriver for that but that's how the rest looked like (After brushing them with water only):
    Photo 8-31-15, 8 49 13 PM.jpgPhoto 8-31-15, 8 49 21 PM.jpgPhoto 8-31-15, 8 49 26 PM.jpg
    Not sure if it's damaged or just dirty.. however I started to see very small brownish things in the water when I flush it.
    Jan 2014
    Discovery Bay, HK
    269
    It's just dirty. Give the shower screen and dispersion plate a good scrub.
    Aug 2015
    21
    Sarah
    If you're feeling adventurous, are even slightly handy, and are out of warranty, have a go at pulling it apart for a deep clean. I did this on mine the other week after owning my machine for 9 years or so, with the odd service here and there. Getting some of the parts apart was.... interesting. But I managed to do it without damaging anything critical. Gave it all a good soak in descaler and manually cleaned before putting back together. Lots of videos on youtube to guide you.
    That said, occasionally I get cloudy water after a back flush, but it usually runs clear pretty quickly.
    David.
    Nov 2008
    56
    Apart from Tartaric Acid I would love to know what the other 40% is.
    An example MSDS for a descaler:
    Ingredients Name, CAS Proportion
    *Citric acid, 77-92-0 >60%
    *Tartaric acid, 87-69-4 5 -10%
    Ingredients determined Not required, Balance not to be hazardous
    The "Balance" would appear to be less than 30-35%.
    Oct 2012
    184
    I've wondered that too... there's probably some base like NaOH to buffer it out? I've used products like that before which just list citric and tartaric acid, but I think the 'triple action' style cleaners also contain some detergents. Bombora's just lists "non scheduled organic acids", "other non-hazardous ingredients" and "water" in its MSDS
    I bet you could read up on some patents to work it out, although I suspect the simpler descalers are just bufferd organic acid solutions. I've been meaning to figure out a citric acid + cream of tartar equivalent for people to use
    Nov 2008
    56
    Most domestic products are mostly citric acid with some other acid in small quantities (Tartaric, lactic, sulphamidic acid, maleic acid). Commercial product use the big gun of phosphoric acid.
    Other addatives can be:
    Aluminium sulfate <1% - not sure of the purpose. It is a flocculating agent so maybe helps keeps things (floc) in suspension to remove particles.
    Sodium carbonate - washing soda/water softner/ph regulator (alkaline)
    Sodium percarbonate - oxidising agent
    Sodium triphosphate - water softner in soaps
    Polyethylene glycol - maybe used as a dispersant to prevent clumping settling of particules
    I am in no way suggesting that people mix up thier own descaler with any of those additives, but it is interesting to know of some of the things put in these products.
    17,415
    I'll just leave it to the experts...
    An industrial chemist, I am not but I do know that exposing aluminium to strong alkalis like NaOH or Ca(OH)2 is a bad thing to do, and dangerous...
    GreenBeanGenii and TC like this.
    Oct 2012
    184
    I wasn't suggesting people expose their boilers to concentrated sodium hydroxide. I also wouldn't suggest they expose it to concentrated citric acid, but a correct mixture of the two would be harmless. HCl and NaOH sound nasty but 1:1 they make table salt.
    Honestly I'm not pulling this out of my arse, I do have a PhD in chemistry
  23. #23
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,359
    I like salt.
  24. #24
    Aug 2007
    163
    Quote Originally Posted by burr View Post
    Thing is not many users on a Coffee forum would have any inkling of the amphoteric properties of aluminium.
    Abuse of aluminium could be far worse than any portafilter sneeze.
  25. #25
    17,415
    Fair enough mate, but a small amount of knowledge in the wrong hands, improperly applied, can be disastrous....
    I wouldn't be encouraging anyone to experiment and try to create a home-brew descaler just because of something they've read in a forum. Much easier, safer and simpler to go with either propriety ready-made compounds from Cafetto or similar, or the weak citric acid solution that a lot of people have been using safely (although not necessarily efficaciously) on their home machines for many years.
    Another common compound that we all use daily but can be very dangerous when it's individual elements are mixed in the presence of an ignition source is H2O.... Makes about as much sense as a reference to salt...
    Oct 2012
    184
    Fair enough Mal, I don't want anyone to damage their machine, I'm just of the opinion that openly discussing ideas and sharing information can only be a good thing.
    People are already abusing their gaggia boilers with citric acid, which at least outside of this forum, appears to be the standard remedy. While there might not be any immediately noticable damage it can certainly cause corrosion over the long term. Some commerical solutions aren't suitable either, nor is your standard backflush powder. My Cafetto proudly states on the back it follows "NSF protocol P152... not corrosive to the espresso machine...", well stick your aluminium shower plate holder in it and see what happens? Once I discovered this first hand I posted it up and saw other users state the same thing - I would have rather read about it first before drinking the first few layers of my backplate.
    Anyway enough for now, all I'll suggest is that people only use cleaning products which specifically state they are safe for aluminium - don't assume otherwise. Regardless of what you use, make sure you flush it liberally with water after.
    Dimal, Buzzbard and mulquemi like this.
  27. #27
    Nov 2008
    56
    Ugly, but reminds me of older Gaggia's that I have pulled apart to fix. I not sure that is scale. I have personally assumed that it is corroded aluminium for the upper boiler. I you pull everthing apart it is easy to clean out and fix. However you will need to replace o-rings.
    If you do open them force water through all the orifices to clean them quickly.
  28. #28
    Dec 2013
    Toogoom, QLD
    931
    I'll stay out of the acid treatment subject but will add that a small amount of baking soda added to warm water will neutralise the corrosive action of malic and citric acid. I bathe boiler parts in this solution after an acid bath; then a good rinse in warm water before reinstallation.
    JojoS and mulquemi like this.
  29. #29
    Jan 2014
    Discovery Bay, HK
    269
    Quote Originally Posted by sprezzatura View Post
    Interesting suggestion but how small an amount? 1 tablespoon diluted to 1 liter of tepid water? If so, it will be perfect for initial rinse after descale.
  30. #30
    Oct 2011
    1,376
    It depends on how much acid is there. Adding more than you need wont be a big deal, provided you rinse it well afterwards.
