Results 1 to 2 of 2
Thread: Help- Gaggia Synchrony Logic Rapid Steam
    Jan 2016
    1
    Today I started having an issue with my Gaggia Synchrony Logic RS. It will disperse a very small amount of coffee (just covering the bottom of my mug) and then the red light will come on and the machine will stop brewing. I've tried everything I can think of such as cleaning the brew unit, de calcifying, lubricating etc. and nothing has worked. Anyone have similar problems or advice? I've only had the machine for a little over a month though it does get used pretty much every day.
    May 2014
    545
    katedid88,
    Welcome along,sorry to hear of your problem.Seems to me your magnetic water level sensor is playing up ( red light on- indicator).
    These auto machines are very dependant on a correct water level to survive and the sensor will quickly lock out everything if the detection fails.
    Have you tried a magnet in the water tank,in the same position to the level float,that would confirm a faulty float magnet / position,might be something as simple as your tank not going into correct position.See if that helps,I've had quite a few autos that have had that problem.
    Hear from you soon regarding your progress.
    Mick.
