Results 1 to 3 of 3
Thread: Boema Single Group Boiler Pressure
    May 2011
    15
    Hi All,
    Managed to complete a refurb of my Boema and want to clarify what the boiler pressure should be sitting at. I got the machine back together and allowed it to heat up and without adjusting it myself, the pressure gauge was at 20 psi. That's how it was before I got it.
    From reading another post, that is way too high, so I adjusted it down to sit at around 13 psi which is around .9 bar. In doing that I think it is too low as my shots are a little light in colour even though the beans are freshly ground out of a new Mazzer grinder and packed well.
    We have an old Brasilia 2 group Portofino at work which continues to poor pretty good shots with the same coffee.
    I will adjust the pressure in higher increments and test but would anyone know what the optimum pressure would be to start with? I realise there are quite a few variables such as accuracy of the gauge itself, humidity etc but wondering if I should get myself a portafilter with a gauge?
    Any suggestions welcome.
    Thanks, Frank.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,120
    Quote Originally Posted by 3hundredspartans View Post
    Hi All,
    Thanks, Frank.
    Are you just getting the reading from the gauge on the machine? That's fine to a certain extent, but not always the most accurate. Also don't confuse boiler pressure and pump pressure. Boiler pressure is generally best set between 1.1-1.5bar depending on the machine. Pump pressure, ideally taken at the group head should be around 9-9.5bar.
    May 2011
    15
    Thanks LeroyC,
    I'm just reading from the gauge on the machine but I can see where you say not to confuse the two. Might just invest in a portafilter gauge to make sure.
    Cheers, Frank
