Results 1 to 4 of 4
Thread: Gaggia Classic Water from Steam Pipe
    Jul 2007
    21
    I hope someone can help!! My machine is puring hot water out of the steam wand when I have it set to flow through the group. Only a dribble through group. I cant turn the steam knob either, it appears jamed. There was a rattling noise just before the "water through the wand" thing happened, just after I had turned the on the hot water switch.
    Any help as to what has gone wrong/how to fix would be appreciated as I am sorely missing my expresso. Plunger ust dosnt do it for me amymore! :-[
    17,213
    Re: Gaggia Classic Water from Steam Pipe
    Id take it back to your retailer abev and see if they can fix it or replace it for you...
    Mar 2007
    73
    Are you mechanically inclined? Good with fixes? tools? etc?
    I agree take it too a retailer and have it fixed.
    Otherwise......
    Have you descaled your machine lately?...
    Tested ur water hardness using basic aquarium kit?...
    Have you removed your shower screen holder and pressure release valve?...
    ie. see link for part im referring too.
    http://cgi.ebay.com.au/GAGGIA-complete-pressure-valve-head-group_W0QQitemZ300133713753QQihZ020QQcategoryZ2067 1QQtcZphotoQQcmdZViewItem
    Have you ever opened your machine?
    Have you ever had it serviced?
    Sometimes the knob on the steam arm can get get jammed easily.
    Remove your lid. look inside where your steam arm is....Pull on the plastic knob..it comes off then try and rotate the brass portion with a set of pliers very gently.
    It should rotate...if not..ur in trouble..you can purchase a brand new steam replacement at supercoffeeman. or take it for servicing. If it does turn...ur fine. Just put
    back the plastic part watching it carefully with the top off...
    This sounds like mega build up of scale..maybe a giant stuck inside or your brew thermostat has died. Simple to purchase and put back in.
    ..heres an excellent troubleshooting link:
    http://www.coffeecrew.com/content/view/290/27/
    cheers
    Jul 2007
    21
    Thanks Pravspresso, have never fiddled with a cof machine before, but can do minor car stuff, household appliances. etc, so I figure worth trying myself if I can get the good info. re wht I need to look at. Your post a great start. Ta
  1. Gaggia Classic - No steam, just hot water.
    By Degrees in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th July 2012, 11:16 AM
  2. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  3. Gaggia Baby Twin - Water instead of steam come out of the steam wand
    By sunbirdj in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th June 2010, 01:15 PM
  4. Gaggia classic -- return pipe
    By hwds in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th May 2008, 09:51 AM
