Results 1 to 12 of 12
Like Tree5Likes
  • 1 Post By Erimus
  • 2 Post By Jackster
  • 1 Post By Kjarsheim
  • 1 Post By Jackster
Thread: Best small machine for travelling
    May 2018
    3
    We cant take our new Breville cafe series in the caravan because its too big.just wondering what the best small, cheaper machine is out there right now. We will always have power so donít want a manual. Donít want a pod machine either! Just want something with a smaller footprint that can make a decent cup of coffee.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,120
    Which Breville model do you have? You could look at the Delonghis. Theyíre pretty basic, but nice small footprint and can make a reasonable coffee if you pair it with a burr grinder and good coffee.
    Nov 2013
    1,122
    The Breville Bambino Plus has had some good things said about it since its release. The Breville 800 series pack quite a punch for the size.
    May 2018
    3
    We’ve got the Breville dynamic duo...so would probably take the grinder and find a smaller footprint machine. This is our second Breville machine and have been really happy with them.
    Jun 2012
    Melbourne, Vic, Aust.
    851
    You could pick-up a cheap used Saeco Via Venezia. Just need to be sure to fill the boiler before and after steaming to avoid burning out the element.
    Senior Member Erimus's Avatar
    Mar 2014
    Kippa-Ring Qld
    318
    Half the battle is fresh beans, you have the grinder so a french press would be in order for the holiday. You'll have more spending money too and if you're desperate for an espresso type coffee you can buy one with your saved money.
    Yelta likes this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,542
    I agree with Erimus, a French press with fresh beans would be a good way to go.
    Dec 2009
    SYD
    499
    Another vote for French press since youíll have access to a grinder.
    Nov 2017
    Maddington, Perth. Wa
    729
    Im going against the French press, to suggest a aeropress. Harder to break, less muck in the cup, easier cleanup.
    Though im thinking of trying a delter press myself.
    They really need good water though. Tis the case across the board though really.
    Dimal and Kjarsheim like this.
    Sep 2016
    45
    +1 for Aeropress (metal filter will make it even simpler) - if you want a great compact setup that's ridiculously easy to use and clean up.....otherwise its a really slippery slope, and depending on what you really want/expect from your kit.
    Dimal likes this.
    Jul 2009
    5
    I took a la pavoni professional on the road with my four wheel drive, although it does not qualify as inexpensive.
    Also I have a a flair which makes excellent espresso shots (and can be used on cruise ships that ban electric appliances).
    The delter and aeropress are great but do not make espresso. Of the two I pick the delter for ease of use and coffee taste.
    Nov 2017
    729
    Yes, I didn't mention the long black makers as it seemed the op was more towards the espresso bent.
    Paired it with a temperature sensor kettle...
    I was comparing my aeropress/metal filter, with the gf French press. Same beans, dose, grind, water, time. Side by side making the long black, she preferred the aeropress 3 out of 3 times.
    Dimal likes this.
