Results 1 to 6 of 6
Like Tree4Likes
  • 2 Post By Dimal
  • 2 Post By level3ninja
Thread: Cleaning BES400 Breville Ikon
    Jul 2009
    73
    Hi,
    I'm trying to figure out a simple way of regularly cleaning this machine.
    It does not have a 3-way valve so as I understand it I cannot backflush with a blind filter (even if I found one the correct size).
    I also have been unable to locate a cleaning tablet holder that would fit this (51mm) portafilter.
    I've been thinking maybe of using just a cleaning tablet or cleaning powder in the single dual wall filter.
    Any suggestions welcome.
    thanks
    Jul 2009
    73
    Ok,
    for decalc I have 'Clean Bean' Descaler solution from Woolies $7 250ml (I believe that this is basically Cafetto LOD).
    I am thinking a Cafetto S15 tablet in the dual wall filter to clean.
    Am I on the right track?
    17,457
    G'day hj...
    Sounds good re: the Cafetto tablet in the filter basket.
    And if the Woolies product is based on Cafetto LOD then that should also do a good job.
    When descaling, always a good idea to thoroughly rinse out the system afterwards to ensure all of the product and any residues have been completely removed. Don't forget the Steam circuit...
    hotjava and level3ninja like this.
    Nov 2013
    1,896
    When cleaning with Cafetto powder or descaling I always rinse well then pull a shot and dump it down the sink to clear out any residual chemicals.
    Dimal and hotjava like this.
    Jul 2009
    73
    I think its a SS boiler - would a soak w/ descaler also be safe with that solution ??
    17,457
    Quote Originally Posted by hotjava View Post
    It should be Ok as I don't believe that the oxidised layer on the s/s will be disturbed, leading to the possibility of s/s pit corrosion.
    Perhaps Lyrebird will spot this the thread and offer his knowledgeable comment...
