Results 1 to 11 of 11
Like Tree6Likes
  • 1 Post By level3ninja
  • 3 Post By Jackster
  • 1 Post By hotjava
Thread: Ulka EX5 pump
    Jul 2009
    73
    Ulka EX5 pump
    Hi,
    I bought an Ulka EX5 pump to service a machine and have discovered it is labelled as 240v whereas generally it seems most are rated at 230v.
    Is this a problem? Did I get the wrong pump for OZ power?
    thanks.
    Nov 2013
    1,927
    All good. Just out of interest, is it the pump voltage you're talking about? They'll all work fine.
    Jul 2009
    73
    Yes the pump voltage. the sticker reads 240V 50Hz 48W
    I looked up specs for the EX5 and discovered that there apparently are 220/230/240V versions ??
    Very confusing.
    Nov 2013
    1,927
    Different countries around the world have different voltages. Parts of Europe are 220 and 230 so a lot of equipment from there will be rated to suit. We run on 240 so the 240V ones are best but with these pumps they're capable of handling 10V +/-. Some other equipment may not be however.
    hotjava likes this.
    Nov 2013
    1,927
    In fact if I had to guess I'd say the 220, 230, 240 ones are all the same internally and labelled differently because it must be cheaper to manufacture a couple of different voltages instead of six.
    Jul 2009
    73
    I'm also thinking it could possibly be a certification thing.
    Here is the datasheet.
    http://files.cemegroup.com/elettropo...33547362392906
    Jul 2009
    73
    For the record my power meter reads 247v so probably all good.
    When voltage varies - Electrical connection
    Nov 2013
    1,927
    Yeah 247 is quite common
    hotjava likes this.
    Jul 2009
    73
    I've also seen references that say the Ulka EP and EX pumps are actually identical internally. The only difference being the plastic or brass outlet.
    Can someone please confirm/deny this?
    If true I can't really see how there would be any significant difference in durability.
    Nov 2017
    Maddington, Perth. Wa
    1,076
    Ex pumps have a hot water rating, the plastic ep are cold water only. But generally, the ex brass nosed pumps seem to be more enduring.
    Dimal, hotjava and Lyrebird like this.
    Jul 2009
    73
    Closer inspection of the pump also revealed imprinted on the red plastic body housing 'ULKA (diode symbol) 230v ~ 50Hz' which seems to support this theory.
    level3ninja likes this.
