Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By eljay
Thread: Breville BES820 removing top panel for repairs
    Jun 2019
    2
    Hi Coffee Snobs,
    First-time poster here. I've noticed some problems with the steam wand on my ageing Breville BES820 coffee machine. I suspect that there is some sort of blockage that needs to be cleared. I'd like to take a look inside and see if I can identify where it is.
    I can remove the rear panel easily (6 Torx screws on the rear, and two Phillips screws underneath), but I can't seem to remove the top stainless steel panel. This is a problem, as I can't get access to most of the internals with the top panel in place. Most 800-series Breville coffee machines seem to have two screws on either side of the group head that secure the top panel (e.g. see https://www.youtube.com/watch?v=V-WCjDRRFFw for Breville BES860XL). As best as I can tell, I can't see any such screws on the BES820. Has anyone else had success removing the top panel on the BES820? If so, how?
    Jun 2019
    1
    When you remove the back panel, give the top a firm whack from the rear towards the front. It just slides off forward. You can see the hooks it has when you look inside from the back. You will find a grounding wire attached to the top, so don't yank on it once it's loose.
    elgordo likes this.
    Jun 2019
    2
    That did the trick. The panel came loose without too much trouble. Thanks!
    Sep 2012
    30
    And all the time I have been working on that tight back window... Thanks!
