Results 1 to 15 of 15
Thread: Sunbeam Cafe Latte *& Breville Grinder
    Jan 2008
    7
    Sunbeam Cafe Latte (EM5600) & Breville Grinder (BCG450)
    I am happy how its working but would like to increase the shot pour time as no matter how I grind the beans it still pours to fast, will get a non pressurised basket help this ??
    As I am in New Zealand who are the Krups agents to contact for this.
    Sep 2007
    Northlandia
    1,365
    Re: Sunbeam Cafe Latte  & Breville Grinder
    Hey dynacam,
    a non pressurised basket is what you need - although you may also find that your grinder doesnt grind fine enough for a great espresso pour.
    Krupps have these guys listed on their website - if they cant help they should be able to let you know who can:
    Groupe SEB New Zealand
    P O Box 64-302
    Botany Town Centre
    East Tamaki
    1730 Auckland
    New Zealand
    E-mail: atyourservice@groupeseb.co.nz
    Tel.: 0800 700 711
    Fax: 0800 700 712
    Good luck!
    Jan 2008
    7
    Re: Sunbeam Cafe Latte *& Breville Grinder
    Thanks I will go have a look
    Nov 2007
    13
    Hi dynacam
    I also own an em5600, I used an angle grinder to make the baskets non-pressurised by removing the outer metal skin, I also removed the plastic from inside the p-f. I have an Iberital Challange grinder which works well with this machine, I find that if I slightly overfill the baskets and tamp fairly firmly I get good coffee shots. It also goes without saying that I only use fresh coffee beans ground as I need them.
    Hope this helps.
    Jan 2008
    4
    ive got a em4800 and a good grinder.
    once you buy the krups filter AND the krups group head seal you will get 27sec perfect pours
    Jan 2008
    7
    Thanks to all replys, I am chassing up on the basket from the local krups service centre ..
    Jan 2008
    7
    I have managed to get a Breville filter basket that fits from the Bar Italia, (part # is ESP4 / 51 1-2 cup filter)
    See this post
    http://coffeesnobs.com.au/YaBB.pl?num=1197963857 (not sure how to make the link)
    With my few tries I am getting a better extraction (20 - 25 secs)
    At this point in time I have not removed the plastic inside the Portafilter !!
    16,540
    Quote Originally Posted by dynacam link=1199656768/0#6 date=1202100311
    See this post
    Great to hear dynacam [smiley=thumbsup.gif],
    Sounds like youre well on your way now 8-).
    Im not positive about this but I believe that you can discard the plastic shield thing in the bottom of your PF now as I think its main purpose is to deflect the stream of coffee coming from the single hole of a pressurised basket and thereby give the impression of a good shot of espresso. With a normal basket, it really only acts as a trap for coffee oils and minute solids that eventually go rancid. This will without doubt give your shots an off taste as well as providing an ideal environment for the harbouring of all manner of single cell nasties :o.
    If it was mine, Id be getting rid of it.... :)
    Jan 2008
    7
    Thanks, If I remove the plastic shield thing will I be left with a "hole" in the bottom of the PF ?, it seems to be attached witha screw ?.
    With the existing 2 spouts I can do 2 singles a 3rd hole will mess things up.
    Would it be better if I got another PF ..
    16,540
    I guess you could always refit the screw after removing the plastic deflector thing.... If it looks like being a bit too long you could then shorten it a smidgen :-?,
    Sep 2007
    Northlandia
    1,365
    If this is the same PF as my old one, the hole in the PF isnt threaded - so without the plastic insert the screw wont stay in.
    16,540
    Quote Originally Posted by m@ link=1199656768/0#10 date=1202162172
    Should be easy to drill & tap to what ever thread you want and then use a short(ened) screw to block up the hole. Where theres a will..... ;)
    Sep 2007
    Northlandia
    1,365
    ...and there I was trying to give dynacam an excuse to buy a Vibiemme ;)
    Jan 2008
    7
    not sure what a Vibiemme is ?? ... but for present I will have to work with what I got, will be living in a caravan around NZ for the next couple of years so space will be tight and the current setup just fits ..
    I am after another PF so I will hack that one around and keep one as it comes ..
    Jan 2008
    7
    Is there any part no for the "krups group head seal" or can I have a model no of a Krups machine its fits, the service people want this ?? as they seem to have lots of different ones ??
  1. Sunbeam Cafe Latte EM5600
    By Grug in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 23rd June 2008, 10:43 AM
  2. Sunbeam Cafe Latte EM5600 coffee not hot
    By shirpam in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd June 2008, 03:06 PM
  3. Just won a sunbeam Cafe Latte EM5600
    Last Post: 11th April 2008, 07:26 PM
