Results 1 to 5 of 5
Thread: can i choke her to death?
    Feb 2008
    171
    Hello dear readers, especially thoes with experience in the area of cheap machines - eg. Ikon.
    My question for you is:
    as the subject sudgests, can i kill the pump by tamping too firmly/having too fine grind?
    a book i found by Daniel Benmayor *"Coffee Art" (2004) - says only ever tamp "gently" to avoid choking the coffee.
    Ive read a few threads about tamping though and sounds like old Daniel B. is full of it. :-?
    Your opinions?
    3,498
    Re: can i choke her to death?
    gmeddy....
    If, like the standard Ikon, you have pressurised or "crema enhancing ::) :P" baskets then you only need a light tamp. The basket limits the flow (via a pin hole in the outer skin at the bottom)...
    However if you replace the supplied basket with a normal one (or use some other machine with a normal basket) then you need to generate the same resistance to water flow.... to get a good extraction. To do this you must compress the puck by tamping to make it "solid".... normally about 13.5Kg of force is applied.
    If you grind too fine or tamp too hard the resistance will be higher and you will get very little, if any, espresso out. There is a bypass valve in most machines which will open and return the water to the reservoir (or back to the input on mains plumbed machines)..
    There is a school of thought which says a very fine grind and a gentle tamp works very well..... but I personally dont subscribe to that theory.
    Feb 2008
    171
    thanks JavaB, im planning on having the depreassurised basket.
    so my little pump should survive even if i do over tamp a fine grind, that sets my mind at ease.
    another question:
    it gets mentioned often, 9g or 18g of coffee, you can weigh your beans before you grind ect,
    what kind of set of scales do you use?
    digital Kmart/tandy job do? :-?
    Mar 2005
    2,165
    Ooh, I reckon this thread about Scales might be a good place to start! ;)
    Feb 2008
    171
    thanks Greg!
    i might do a search on that auction site n see what comes up...
  1. Death by Caffeine
    By TC in forum Off Topic
    Last Post: 26th November 2011, 04:54 PM
  2. Beans causing grinder to choke / slow
    By boots in forum General Coffee Related...
    Last Post: 15th September 2009, 02:29 PM
  3. a death in the family?
    By coffeebreath in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 9th May 2009, 12:19 PM
  4. Death of a favorite cup
    By Javaphile in forum General Coffee Related...
    Last Post: 31st March 2009, 11:49 PM
