Results 1 to 2 of 2
Thread: Sunbeam 4800 Group head seal
    Sep 2007
    2
    Ive been using the krups baskets on this machine for a while now (around 6 months). *In the last couple of months Ive had water leaking from the brewing head every now again. *Tightening the filter handle a little bit more each time has been workable, but Im at the point now where the rubber seal (which I assume is the source of the problem) needs to be replaced. *
    I read a couple of threads here where people have recommended replacing the sunbeam seal with a krups one. *Is there any significant difference in the two? *What advantages does the Krups have? *Anyone got a part number for the krups seal?
    Tim
    DONT USE
    Jan 2008
    432
    Re: Sunbeam 4800 Group head seal
    hi tim
    the sunbeam seal seems to last quite well, the seal needs replacing when you need to pull the filter handle all the way to the stop
    a common problem is that the 4 screws holding the filter support come loose and need to be retightened.
    these screws are viewed from underneath were the filter handle goes in
    dont over tighten as it is only aluminium
    graham
  1. Group head seal help
    By blaggon in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th February 2012, 12:08 AM
  2. Sunbeam EM6900 Group Head Seal issues
    By bradgtv6 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th June 2011, 09:44 AM
  3. Sunbeam Group Head Seal
    By GBISing in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th December 2009, 05:06 PM
