Results 1 to 12 of 12
Thread: Presure in PF after shot
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    941
    I am using a Sunbeam Cafe Crema and every now and then, when I have finished a shot as I release the PF I get sprayed with grinds and water from the PF :o . This does not happen every time but often enough to be causing concern as the spray could burn.
    I have tried under dosing/overdosing and it still happen about 1 in every 5 shots. :-[
    Any advice would be appreciated
    Feb 2008
    130
    Re: Presure in PF after shot
    If you leave the pf in place for a few seconds the pressure will leak through the puck. Most higher end machines have a 3 way selinoid, that releases the pressure after a shot, but some cheaper machines dont have that so the pressure stays just above the puck, untill it bleads throught the coffee...
    Dec 2007
    941
    Thanks,
    I have left it in position for different times up to a minute and still on the odd occasion it retains pressure and I get an explosion on release. :o
    Stan
    Feb 2008
    130
    Are you possibly grinding too fine? How is the shot, maybe the coffee is too fine and creates a barrier??? I dont think there is much else you can do to help it, maybe just release the pf slowly and let it seep past the seal? By the way, its calledd a pf sneeze sometimes...
    Dec 2007
    941
    Thanks, I will back off on the grind and see what happens.
    Sep 2007
    Northlandia
    1,365
    I think this machine does have a 3-way valve, my EM03500 certainly did. Perhaps its blocked. This would make sense if hasnt been backflushed regularly - happened to my old Sunbeam after a couple of years of regular use with no maintenance ;)
    Dec 2007
    941
    Thanks I will check that out. I am not sure if it has a 3 way valve but anything is possible. I have only had it about 3 weeks. :-/
    The instruction booklet does not describe backflushing as an option.
    Jan 2008
    476
    My saeco vv has the same problem. Too fine a grind will certainly contribute to the problem, but I find that I need to pour a certain amont of coffee inorder to depressurize the basket. So even if Im pulling a double ristretto, I will continue the pour (into another glass of course) untill Ive poured the equivalent of a double shot. By this time my machine has lost its steam. Are you always pouring the exact amount of coffee?
    Dec 2007
    941
    I let it pour until I get blonding. The time varies depending on many factors as I am in the first stages of becoming addicted to making my own expresso. So the tamp pressure probably varies to a certain degree even though I try to be consistent.
    I bought this machine to see if we would stick with making expresso and not return to plunger/dare I say it, instant coffee :o.
    Sep 2006
    124
    Hey, I used to use a Gaggia Carezza, which doesnt have a solenoid. I used to find the same with the portafilter on every shot. What you can do is pull about 30-60 seconds of water through the puck after you have finished your shot (take the cup away and keep pulling blonded coffee into the tray or a dirty cup). You wont have any problems if you do this ;)
    Dec 2007
    941
    I seem to have fixed the problem by adjusting the grind. But I will keep your remedy in mind if it starts again.
    Thanks all. ;) ;)
    Feb 2008
    130
    Glad we could help,
    Happy drinking
  1. Grind differnce between single shot and double shot?
    By Wilki in forum General Coffee Related...
    Last Post: 9th April 2012, 01:57 PM
  2. Your first GOD shot?
    By Roz in forum General Coffee Related...
    Last Post: 12th June 2011, 08:08 PM
  3. Wet puk after shot
    By kammy in forum General Coffee Related...
    Last Post: 26th July 2010, 07:45 PM
  4. Pull shot.. great! Pull next shot.. whoooa waterfalls ahead!
    By simonsk8r in forum General Coffee Related...
    Last Post: 19th June 2010, 11:59 PM
  5. The God Shot
    By afton in forum General Coffee Related...
    Last Post: 16th July 2008, 10:05 AM
