Results 1 to 7 of 7
Thread: Non-pressurized portafilter for Saeco Via Venezia
    Mar 2008
    3
    I would like to obtain a non-pressurized portafilter and filter basket for a Saeco Via Venezia espresso machine. Could anyone tell me where I could obtain one? *Many thanks. *Potio
    Dec 2007
    3
    Re: Non-pressurized portafilter for Saeco Via Vene
    I noticed the filter basket on a display model Saeco VV at a coffee supplies shop today was a single wall (non-pressurized). *The shop was in Pymble NSW if that helps. *Im sure any of the CS sponsers that stock Saeco would be able to let you know if they have single wall baskets for the VV.
    May 2007
    Perth, Western Australia
    3,150
    The basket is fine, its the portafilter that needs changing, I just took the basket out of my old VV and put it in my sons DeLonghi to make his pf non-pressurised. Removing the spring loaded innards of VV would probably make it non-pressurised?
    Jan 2008
    476
    I have a vv and have done this modification. You do not need to buy a different portafilter (unless you want to keep the presurrized basket ???).
    Just unscrew the base of the portafilter.
    Pull out the plastic mechanism in the base.
    Then you have to poke the false floor out of the upper part of the portafilter. Youll notice that theres a black plastic base with a pin hole. You need to remove this and the red o-ring seal. Pushing it out from underneath with something like a thermometer probe will do it.
    The portafilter is now entirely depresurrized.
    I then sent my basket to Greg Pullman in WA and he made a tamper to fit it perfectly. very happy with the results. Its a night and day difference. feel free to pm if you have further questions.
    Kit
    Mar 2008
    107
    Agree with smokeydeck, just remove the guts out of the existing PF.
    I did this mod a couple of months ago, & am happy with the results.
    I had to work on my grind/tapdown/tamping technique though, nowhere to hide when its unpressurised. ;D
    Cheers...............Sean
    16,546
    Quote Originally Posted by scooter link=1208847964/0#4 date=1209038271
    Yeah but the excellent coffee afterwards is well worth it....... ;)
    Mar 2008
    107
    Quote Originally Posted by Mal link=1208847964/0#5 date=1209054708
    Amen to that. :)
  1. Saeco Via Venezia Bottomless Portafilter
    By CafeLotta in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th October 2012, 11:12 AM
  2. Non-pressurized portafilter for Saeco Via Venezia
    By Cristen in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th June 2011, 10:36 PM
