Results 1 to 3 of 3
Thread: My new Ristretto sounds like a machine gun
    May 2008
    2
    Hi all, finally took the plunge (so to speak) and bought myself a Sunbeam Ristretto to replace my plunger. Ive followed the instructions, filled up the water reservoir, let it heat up, pu tin the filter, and tried to run water through with no coffee. Unfortunately I get no water and the machine sounds like a machine gun. *:-[
    The instruction book says a loud noise can be due to no water, or the reservoir not installed correctly but Im stuffed if I can see whatw wrong. Any suggestions? I made the mistake of getting all my coffee for this week ground for the espresso machine so I cant even use the plunger. *:(
    Apr 2008
    11
    Re: My new Ristretto sounds like a machine gun
    I had the same problem when i first fired up my Ristretto. Turn it on, get it running (so it makes the hideous noise), then quickly (dont want to run it too long without water) apply pressure down on the water reservoir. I found when i did this, almost instantly i heard the noise decrease and water flow into the boiler.
    May 2008
    2
    Thanks Mitchell, got it in place with a bit more pressure in the right spot. Now I need to work out how to make a decent cup of coffee, first one went straight down the sink. ::)
  1. SB Ristretto - (Subjectively)A Good Little Machine
    By mitchell_bb in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 25th April 2008, 04:08 PM
  2. Second crack sounds...
    By NewToEspresso in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 11th July 2007, 12:50 PM
  3. [m]: RANCILIO BEAT? SOUNDS THAT WAY.
    By TC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th April 2007, 03:55 AM
  4. RANCILIO BEAT? SOUNDS THAT WAY.
    By pravspresso in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 11th April 2007, 03:53 AM
