Results 1 to 7 of 7
Thread: non pressurised filters with breville 800
    Jun 2008
    4
    thanks for all the info on this forum. have had a breville 800 for ages but read about the non PF baskets on this forum, they arrived today.. Excitedly I made the first cup - coffee and hot water spurted all around the holder. Tried again with more tamping (using breville scoop/tamper - will get proper tamper tomorrow), same deal. Seems like the non PF basket doesnt quite seal properly, or is it to do with the black plastic in the bottom of the holder?
    Anyone else had this experience or have any tips for me? Look forward to your comments. :(
    psaigh
    Re: non pressurised filters with breville 800
    are you using the breville baskets or the krups ones? Either way it still seems wierd, maybe take out the rubber seal at the shower screen and give it a thorough scrub then re assemble (undo the screw where the shower screen is) and see how that goes.
    Jun 2008
    4
    the breville bar italia filter as recommended on the forum, fits snugly into the holder but then water and coffee spurt out. Tried no coffee, just water and starts off fine, but then starts to leak out, under pressure from the shower head, will try as you suggest and let you know. Thanks
    Jun 2008
    4
    ah ha!! just did as suggested, rubber washer is completely perished. Trying to remove and clean shower head, back to breville for another spare part - thank you so much, will keep you posted ;)
    psaigh
    No probs, hope it all goes well. Keep us posted ;)
    Jun 2008
    4
    rubber ring replaced, tamper purchased, now I just have to perfect the grind and were off! Thanks for you help psaigh
    Apr 2008
    2
    hi Crantock, do you remember what the part number was for the rubber ring. I recently bought the bar italia filter and am now having a simular problem.
  1. Breville BES250 - Single wall filters?
    By Neeko73 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th May 2013, 05:19 PM
  2. Tamper for BSWF100 (Breville Single Non-Pressurised Single Wall Basket Filters)
    By uaena in forum Brewing Equipment (non-machine specific)
    Last Post: 2nd December 2012, 07:01 AM
  3. Non-pressurised basket from Breville 860 for 800es??
    By Kofi_Snob in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 18th June 2009, 08:48 PM
  4. Do super autos use pressurised filters?
    By t30sxh in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2009, 11:27 AM
  5. Non pressurised filters for thermoblock machine?
    By dischucker in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd May 2006, 03:46 PM
