Results 1 to 2 of 2
Thread: breville ikon leaking valve
    Jun 2007
    7
    Long time no speak.
    But my Ikon is well out of warranty by now, its brewed quite a lot of coffee in its life and needs some help. The valve that controls the wand has started to leak quite badly, to the extent that during the brew process there is a constant stream of water coming out, and this seems to be affecting the pressure available to the brew. Im using single wall baskets.
    Is the valve able to be removed and cleaned? Or replaced? Has anyone else experienced this situation or have a suggested remedy? Id prefer to fix rather than replace at this stage.
    Gaz
    Jun 2007
    7
    Re: breville ikon leaking valve
    Heres an update on the steam valve. I pulled the machine apart (not difficult) and removed the valve. Its made of brass but the mating surfaces of the valve itself seem pretty poorly machined. Surface irregularities are what allows the leakage.
    I tried cleaning it up with a bit of grinding paste, but without any improvement. Then I tried to buy a replacement valve - told that they are not available as a service part.
    So much for the Ikon - pity, it made a pretty good cup. If you have one, Id recommend not tightening the valve more than is absolutely needed, the material its made from is quite soft.
    My solution: Ive ordered a Rancilio Silvia.
    Gaz
  1. Diadema Junior Plus leaking valve
    By tshirley in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 23rd August 2012, 02:24 PM
  2. faema due-s opv valve leaking
    By stuartm in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th October 2011, 08:23 AM
  3. Water Leaking from Ikon
    By Secksy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th August 2011, 10:02 AM
  4. leaking valve - new VBM domobar super
    By bieman in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th November 2008, 04:19 PM
  5. Leaking Silvia Solenoid Valve
    By grimsby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th March 2008, 08:08 AM
