Results 1 to 6 of 6
Thread: EM4800 - weak & wet steam
    VC
    VC is offline
    Apr 2008
    24
    Does anyone know what might be causing weak and wet steam on my EM4800? I recall, once upon a time, that the steam could actually cause a whirlpool in my milk jug while steaming... now that is a distant memory.
    I have descaled my machine, stuck the wand in a pot of boiling water (in an effort to dissolve any muck that might be stuck inside)... but still no joy.
    It still steam the milk... it just takes forever, which means that the end product is reasonably watery.
    Might next guess is that the o-ring might need replacing - something I did before when I noticed excessive steam was gushing out of the interface between the machine and the steam wand.
    Any thoughts? Also, any thoughts on whether its possible to open up the machine and tweak the steam pump to make it more powerful or drier?
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    Re: EM4800 - weak & wet steam
    Check that the steam tip is not clogged with old milk. If it is you will need to use the pin that comes with the machine under the water tank. If it has built up over time soaking in hot water will not remove it. The plastic spoon that comes with the machine has a spanner section for removing the steam tip. :)
    VC
    VC is offline
    Apr 2008
    24
    I didnt realise the steam tip could be unscrewed! Now I know why there are hex holes in the scoop! Thanks for the tip.
    Unfortunately, the steam tip is fine.
    Any other ideas? I am not hopeful about the situation improving by replacing the o-ring because, if it was an o-ring problem, Id notice steam escaping where it shouldnt... but this is not happening at the moment...
    Dec 2007
    948
    Have you tried descaling the machine? You could have a build up blocking the water channels. Use the recommended chemical - Dont use vinegar see another post as to the consequences of using the wrong stuff. The below link should tell you more about descaling.
    http://coffeesnobs.com.au/YaBB.pl?num=1212802805
    May 2008
    4,189
    This was a machine I briefly researched and rejected it fairly quickly. You could try soaking the steam nozzle in cleaning solution but I would say its the pump.
    If it is under warranty, take it in for repairs; if it isnt, dont throw good money after bad.
    e.g. http://www.productreview.com.au/showitem.php?item_id=6444&section=REVIEWS&order_by =item_rate_score&is_asc=1
    VC
    VC is offline
    Apr 2008
    24
    Resolved!
    If anyone else has this issue, heres what I did to fix the problem:
    - Got some new o-rings from the plumbers co-op . They gave them to me for free to save the paperwork. I think they were size 5. These go above and below the discharge point of the steam from the main machine (not the wand). Remove the wand and youll know what I mean.
    - Got some slightly larger o-rings and put one between the bolt (for the wand) and the wand itself, and another between the wand and the machine-proper. These o-rings were from a standard tap washer kit.
    The result is that all the steam now exists from the steam wand and not through little gaps here and there.
    The steam is now as good as new and Im a happy chappy. Im seeing whirlpools and textured milk that I thought my machine could no longer produce. The difference is amazing.
  1. 6910 very wet, weak steam
    By perko88 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th March 2014, 10:57 AM
  2. Bezzera BZ99: why is my steam so weak?
    By early_morning_ in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th December 2012, 07:52 AM
  3. la cimbali m21 weak pressure through steam wand
    By mnimos in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 23rd September 2012, 03:01 PM
  4. EM4800 Steam Wand Expelling Coffee
    By Davidlissimore in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 11th July 2011, 05:32 PM
  5. Sunbeam 6910 weak steam......please help!
    By albad in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th April 2010, 01:13 PM
