Results 1 to 5 of 5
Thread: Sunbeam EM4800
    Jul 2008
    3
    Sunbeam EM4800
    Steam is escaping past the securing screw for the steam nozzle even though the screw is secured into the fitting. Is there supposed to be a washer between the screw and the nozzle? Even with the screw secured, the nozzle is loose against the valve.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    Re: Sunbeam EM4800
    On mine there is a washer between the screw and steam arm and the steam arm and the machine. :-/
    Jul 2008
    3
    Re: Sunbeam EM4800
    Thanks Stan
    Looks like it was missed at the factory. It lasted this long without it but now it wants to play up.
    Do you know what material the washer is made from ?? Copper, fibre or other
    Dec 2007
    948
    Re: Sunbeam EM4800
    My mistake - I just pulled mine apart. The washer was an optical illusion. No washers at all. It is just a tight fit. Check tighten your screw and see what happens - it should be very tight. Sorry for the misinformation :-[
    Jul 2008
    3
    Re: Sunbeam EM4800
    Thanks Stan
    Might be getting a new machine sooner than I thought
  1. Sunbeam EM4800 - questions
    By StephenK in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 14th October 2010, 03:44 PM
  2. What to do with an old Sunbeam EM4800?
    By jpagitz in forum Brewing Equipment (non-machine specific)
    Last Post: 21st October 2009, 11:25 PM
  3. Ive given up with the Sunbeam EM4800
    By p38arover in forum Brewing Equipment (non-machine specific)
    Last Post: 12th May 2006, 11:35 PM
