Results 1 to 4 of 4
Thread: Gaggia Espresso Steam Tube Flows Backwards -- Plea
    iNik
    My Gaggia Carezzas steam water tube (the one that goes from the reservoir directly to the boiler) is flowing backwards. So when I turn on the steam setting, it just pumps boiling hot water out of the tube instead of sucking cold water in for steam. Needless to say, this makes it impossible to make steam.
    I did take the machine apart (including the boiler) and put it back together in order to clean the boiler. (There had been HUGE scale build-up since Id neglected to de-scale it for a year or more -- I know, bad plan.) I was pretty sure Id put it back together properly (I kept close track of where parts went, and took photos as a guide, too), but now Im not so sure.
    Can someone please instruct me on how to fix this problem? Failing that, any insight into how that particular input hose is supposed to work (I dont see a pump in the boiler, and the main pump doesnt run when Im just heating the steam up) so that I can troubleshoot it myself. A link to a repair guide would also be nice. (especially a layout of plugs and their purpose -- itd be nice to disable the heaters so that I can troubleshoot without burning myself repeatedly) Thanks a lot!
    FYI: My wife is desperate for coffee and the machines been busted for over a month, so I cross-posted this same question to alt.coffee, wholelattelove.com, and home barista
    DONT USE
    Jan 2008
    432
    Re: Gaggia Espresso Steam Tube Flows Backwards --
    hi inik
    there is a relief valve on the base of the steam valve that returns to the water tank
    inside is a ball, sounds like it might be crudded up or
    if you dissasembled it , it could have been assembled back to front
    graham
    iNik
    Thanks, Graham, it looks like thats the problem!
    Except that, see, theres another problem: I dont have that little rubber ball AT ALL!
    Isnt that always how it is? You take a thing apart VERY carefully, but theres that one little tiny rubber piece that gets away. :(
    Any thoughts on how I could go about replacing that?
    DONT USE
    Jan 2008
    432
    can order through your local gaggia service agent
    gaggia part # EF0061 - rubber ball
    EF0111 - oring - fitting to valve
    graham
  1. A plea to all popper roasters consider an upgrade to something better!
    By lionfish in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 10th March 2012, 07:41 PM
  2. Steam wand replacement on Gaggia Espresso Pure to Rancilio Silvia
    By goddamn in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th June 2011, 03:51 AM
  3. Gaggia Baby Twin - Water instead of steam come out of the steam wand
    By sunbirdj in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th June 2010, 01:15 PM
