Results 1 to 5 of 5
Thread: Koala vice versa shower screen removal
    Dec 2007
    9
    I recently picked up one of these for free, and as seems to be the case with many machines, it just needs a clean up.
    Of course, in the process I pulled the machine to bits - many irritating fancy screw heads - pics of innards to follow.
    The shower screen appears to be held on by a brass screw with two holes in it. It looks like there might be a special tool that fits in the holes - something like a tiny version of an angle grinder wheel removal tool.
    Ive tried circlip pliers - about the right size - and other forms of butchery without success.
    Suggestions please.
    Simon
    Apr 2008
    Brisbane
    5,113
    Re: Koala vice versa shower screen removal
    I have purchased a cheap set of driver ends for the cordless drill and it has one of those in it
    They are hex in shape so you can use a socket or spanner to undo it
    sdg
    sdg is offline
    Mar 2008
    368
    I assume from your mention of fancy screws that youve already got a set of "weird-head" screwdriver bits?
    Dec 2007
    9
    Thanks both. Ive no shortage of odd screwdriver bits, and the one pictured would have done the job on the top screws perfectly, if I could have found it in time.
    The tool Im looking for is to fit the screw holding the showerscreen in place. It is brass, about 12mm across, and has two 1mm holes in it about 7mm apart.
    I need to know if there is a tool, and if the screw is standard thread or reverse thread.
    Simon
    16,540
    Quote Originally Posted by abaddonxi link=1217978495/0#3 date=1218070357
    Simon
    Gday Simon,
    I know that watchmakers have tools very similar to this and also adjustable too. Maybe a trip to your local W/M will have it off in a jiffy....
  1. NS MAC Digit Dispersion Screen removal
    By skydragondave in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th February 2013, 03:22 PM
  2. shower screen removal
    By kooky in forum General Coffee Related...
    Last Post: 6th December 2009, 10:04 AM
  3. Vice Versa - Koala Evolution Coffee Machine
    By razia in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 6th September 2009, 06:27 PM
  4. Expobar Leva shower screen removal
    By Thundergod in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th May 2007, 10:49 PM
  5. 6910 - The second shower screen
    By barri in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th April 2007, 07:47 PM
