Results 1 to 7 of 7
Thread: Vibrating manometer noise
    Feb 2006
    2,334
    Hey guys,
    I have a rotary pump HX machine which makes a vibrating noise similar to vibe pump machine when brewing espresso or backflushing.
    I have set my rotary pump to approximately 9 bars with pressure gauge portafilter. Rotary pump in a procon and sounds like any other rotary Ive come across, humming quietly when engaged.
    Symptoms:
    - vibrating brew manometer needle which erratically flickers between a range of pressures.
    - vibrating noise coming from the manometer and not rotary pump.
    Can anyone shed some light on this? Do I just have a bung manometer? The techie at work said it could be 100 reasons why its doing it, but cant say unless he actually sees the machine. Id rather do the work myself because I dont want to lug a 60+kg machine to work.
    David.
    May 2008
    600
    Re: Vibrating manometer noise
    I had this after reinstalling my motor and pump. For me it was the wire from the capacitor vibrating on the motor casing. You wouldnt think it could make much noise, but it was really loud. Once i bent the wire back, all good again. maybe check all wires and hoses on and around the motor/pump?
    by the way, i like your timer.
    Feb 2006
    2,334
    thanks damian, but I dont think its the pump.
    As I said, the brew manometer needle vibrates like crazy when engaged under load, causing one hell of a racket. When flushing the group, the noise is almost non existent but the needle still vibrates.
    May 2008
    600
    ok fair enough, I just thought maybe it could be vibrations down the line a bit, or touching the pressure gauge pipe. for example, I also got noise on my frame where the hose (about 1ft away fromt eh motor) touched.
    17,123
    Hi David,
    Have you bled the feed line to the manometer/gauge mate? Entrapped air is one reason that this can occur...
    Feb 2006
    2,334
    thanks Mal...I bled the feed line...still no good.
    I may gamble and just buy a new dual manometer and see how that goes.
    17,123
    Ah, OK.... :(
    Probably a damping issue then. You can get self-damped gauges from a number of manufacturers so it might be worth your while to look into this option mate,
  1. Manometer on coffee machine
    By kai888 in forum General Coffee Related...
    Last Post: 6th September 2011, 11:06 AM
  2. VBM Levetta vibrating
    By MarkC77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th March 2008, 12:35 PM
  3. Vibrating vs Rotary Pump
    By srm in forum Brewing Equipment (non-machine specific)
    Last Post: 29th October 2007, 09:19 AM
  4. Vibrating Giotto
    By newbean in forum Brewing Equipment (non-machine specific)
    Last Post: 18th March 2005, 07:30 PM
