Results 1 to 27 of 27
Thread: 10 steps making an espresso in photos
    Oct 2008
    55
    Hi,
    not sure if this is the right forum for this.. but just took a bunch of pictures of my 10 steps MO making an espresso shot..
    here they are..
    the participants
    Grimac One Group
    Mazzer Mini with doserless mod
    Groovy Tamper (me creation;))
    Naked PF and tamp base
    Coffee and scale
    to the 10 steps...
    1- preheat the PF and cup
    2-weight the coffee
    18Gr for triple basket
    and to the hopper
    3- clean/dry the PF
    4-grind the coffee, lot of clumps at this point
    the metal mesh and the brush will take care of the clumps
    5- coffee in the PF ready for labeling and tamp
    groovy tamper took care of the "pigtalis"
    about 30lbs or pressure *
    6- the extraction (about 30 seconds)
    7- the best part, taking care of the extraction
    8- cleaning the group head, every shot.
    9- knowbox in action
    sad looking puck
    10-cleaning the PF
    clean and ready to do it again..
    DONE..
    Hope you like the pictures.. if it contribute to your espresso making experience GREAT, if have any advice to improve mine please let me hear it..
    Juanjo
    Nov 2006
    1,077
    Re: 10 steps making an espresso in photos
    Hi There
    Do all your tampers have the ridges in the bottom of them?
    If not, how different is your technique / results in using your different tampers (i see you have a number of them on top of your machine)
    Mal
    May 2008
    4,114
    Good one juanjo.
    I couldnt help noticing that you seem to be underdosing as the level of grounds in the basket seems quite low (last photo in step 5). This would contribute to your sloppy puck shown in step 9 but the pour and shot in step 6 looks great.
    What I do after every shot now is use a blind filter in my handle an jiggle it while inserted loosely in the head. Surprising how much grounds are picked up even after brushing and flushing.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Ignore the others... ;)
    Opps... Yep agree a little under doased maybe = sloppy puck.. Then again what did it tast like ;D
    I want your Group Handles / Group Holder and Tamp block.. And I want them now.. :D
    If not, then at least the pattern / drawings such that I can do teh same with out all the hard work ;)
    Have just bought a Solid bench and now looking to obtain a Bench top Lathe.. Am after a reasonable metal lathe and as such I can do a little wood stuff as well..
    OH... sorry off topic... Was all about teh hardware and not the coffee ::)
    Apr 2008
    Brisbane
    5,113
    Yes
    I agree under dose & sloppy puck
    That looks to be a ridged LM basket and the tamped coffee grounds should be up to the ridge. Thats about 18 grams on a double basket
    I like the wooden PF stands ;)
    Oct 2008
    55
    hey guys.. thanks,
    Mal,
    most of my tamper are euro convex (Pullman,EPW,Espro(US convex), ext) the other one with "groves" is a RegBarger, the C-ripple. BUT the "groves" are WAY to shallow and make no difference in the tamping IMHO.
    I made that tamper with much deeper groves.. and what I notice it that since Im using it I have no more problems with channeling (AKA pigtail).
    Its a wood tamper, and have to be a bit more mellow when tamping..but the end result is great.
    Flynn,
    not sure if I agree about the undersosing.. since I weight the coffee before grinding and there is very little to no waste when leveling..
    good tip about the blind filter, thanks.. Ill give it a try..
    what I do every week/10 days is mix some Pully Cafe Detergente with some hot water in a blind basket and backflush it that way... trying to keep the group head squiky clean..;)
    Oct 2008
    55
    I had a laugh..
    all the wood parts are made by me.. handle, tamp base, even the tamper...
    to bad you guys are so far from NY, otherways Id offer a cup of coffee while I made those part for you..;)
    Apr 2008
    Brisbane
    5,113
    Juanjo
    No matter what machine and basket combo you have
    The tamp level should be a hairs whisker under the group head shower screen after you lock in the PF
    Find that depth level in your basket with a little trial & error and use it for future reference
    May 2008
    4,114
    Quote Originally Posted by 0B34202F2B2E410 link=1239648322/5#5 date=1239666965
    not sure if I agree about the undersosing.. since I weight the coffee before grinding and there is very little to no waste when leveling.. *
    As I said, your pour and shot looks right. It just looks underdosed both in the basket and by the puck. If the coffee tastes great then a soggy puck is of no consequence.
    Another tip is to carefully remove the group head gasket and clean out the group head. I use a largish flat head screw driver *gently pressed against the shower screen near the rubber gasket and levered from either side using the two cut away areas (you can see these in the second photo of your step 8. Mine levers out quite easily but have a spare gasket and shower screen available just in case.
    I then give the group head area a good scrub with a solution of coffee detergent and a toothbrush
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    I am interested in those beans mate. A little dark for my personal preference and uneven? not that uneven is bad sometimes it provides differing flavours across the different roast levels.
    What are they and what roast level are they please?
    Cheers and great pics !
    Oct 2007
    New Zealand
    1,162
    PS: I get 21 grams in my double basket so 18 for a triple would have to be shy of what it is capable of IMO anyway.
    Oct 2008
    55
    Chris,
    indeed, the Kenya greens are GREAT..
    I done many roast with them.. and they dont disappoint..
    About the undersosing it may be some true if my "goal" was a good looking puck.. ;D
    or if trying to pull a 2oz+ shot..
    for *a 1.5 OZ shot *18gr is perfectly STRONG..
    regardless Ill keep it in mind..;)
    16,960
    Gday Juanjo...
    For some reason mate, I cant get the images to load in FF3.07. I can Right-Click on them and select to download in a new Tab but not on the page theyre linked in. Weird.... :-?
    Does anyone else using FF3.07 experience this weirdness?
    Mar 2008
    466
    Im using FF3.08 and no problems here.
    16,960
    Quote Originally Posted by 74584B4D50585566745657525C40390 link=1239648322/13#13 date=1239696788
    Rightio MM,
    Ill update to that version and see what happens... :)
    Oct 2007
    New Zealand
    1,162
    Hi Juanjo
    Loving that tamp stand too !
    CB
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 46796D6266630C0 link=1239648322/6#6 date=1239667228
    I had a laugh..
    Look... I am happy to make a coffee on ya behalf, while you make a Tamp stand / Group stand ;)
    When itd done... We can work out teh shipping :D
    Need to get me a lathe ASAP..
    One coming up in Melbourne soon.. But pick up only :(
    In poor shape, but that just means some Quality time rebuilding etc...
    16,960
    Quote Originally Posted by 5F72767A771B0 link=1239648322/14#14 date=1239699635
    Ah well, that didnt work. Dont know whats happening so will just stick with it for now. Doesnt do it on any other image links, just this thread,
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 0E23272B264A0 link=1239648322/17#17 date=1239716783
    I use FF 3.0.8 no probs here
    Just a thought :D
    Mal you may need to restart the computer for the update to take effect ?
    Jun 2007
    85
    Hi JJ...can you tell us a bit about the doserless mod for your Mazzer, please...I am thinking of doing away with the doser and yours looks great...Ive seen a vid of you using it and I reckon its a winner...cheers
    May 2008
    4,114
    Quote Originally Posted by 436E6A666B070 link=1239648322/17#17 date=1239716783
    These images arent directly uploaded into CS but linked to JJs Photobucket site. Perhaps that is why they arent displaying properly for you; your browser needs to load the images in the cache for them to be displayed but, for some reason, isnt doing it automatically. When you download into a new tab, you are forcing the download.
    Can you view this in FF?
    See if you can find another post with Photobucket links and check if the pics can be viewed OK.
    You dont need to restart your PC after a FF upgrade - just restart FF. I dont think it is a browser version problem but its worthwhile checking to see if the same problem occurs in IE or even completely reinstall FF (which is probably overkill for one small glitch).
    Oct 2008
    55
    yeah.. a lathe is a must..
    thats my other setup.. shouldnt show it.. what a mess.!! ;)
    Quote Originally Posted by 7B545D5F48775B545B5D5F575F544E3A0 link=1239648322/16#16 date=1239713242
    I had a laugh..
    Look... I am happy to make a *coffee on ya behalf, while you make *a Tamp stand / Group stand *;)
    When itd done... We can work out teh shipping * :D
    One coming up in Melbourne soon.. But pick up only *:(
  23. #23
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6E51454A4E4B240 link=1239648322/21#21 date=1239751352
    yeah.. a lathe is a must.. *
    Did not see my coffee or extras being made up? :o
    In fact it looks rather clean ::)
  24. #24
    10,496
    My avatar is in photobucket.
    Can you see it above this sentence Mal?
  25. #25
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 536F7269636275606863070 link=1239648322/23#23 date=1239765451
    Sorry.. Photo Shopped... Show me the u tube vid of you doing the pour :D
  26. #26
    16,960
    I had a laugh....
    I use photobucket too for all my image links so have never had the problem before.... Anyway, this is way off topic so best get back to Juanjos terrific How-to Guide... 8-)
    Jun 2007
    85
    Quote Originally Posted by 75627171170 link=1239648322/19#19 date=1239718950
    "BUMP !!"
    hi juanjo....just wondering if you saw my earlier question on your doserless mazzer mod...could you tell us a little about it, please ??
    thanks for any info...
  1. Breville 800ES +BCG 450- Help on making good espresso
    By famreeks in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 29th April 2011, 05:13 AM
  2. Are Too Many Steps Never Enough....
    By Ryjoda in forum Grinders
    Last Post: 5th February 2011, 10:33 PM
  3. Problems making good espresso on Expobar Leva
    By icecreamfreak in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 19th December 2010, 09:39 PM
  4. Espresso making DVD
    By afton in forum General Coffee Related...
    Last Post: 15th July 2008, 07:19 AM
