Results 1 to 12 of 12
Thread: What is the current draw for a 2 group commercial machine?
    Feb 2009
    239
    Hi All,
    I am doing the technology consulting for an enterprise technology roadshow next week and have been asked what the current draw would be on 2 x commerical machines so they can provision adequate GPOs.
    Does anybody know how much a single machine will draw?
    Andrew
    Apr 2008
    Brisbane
    5,113
    Re: What is the current draw for a 2 group commercial machine?
    In general
    One can get both
    10 amp & 15 amp depending on the make and model per machine
    Aug 2004
    2,312
    As KK said......it depends.
    Therefore there are 2 alternatives:
    a) Contact the equipment provider and ask them about what they are specifically providing OR
    b) Simply provision for 2 x 15 amp circuits.
    Dont forget to provision an extra 10 amp socket for a grinder.
    Regardz,
    Attilio.
    very first CS site sponsor.
    Feb 2009
    239
    im not quite sure what kind of machine they will have, but judging from last year it will be a 2 group, similar to a san marino.
    A general rule of thumb on this is good, i dont need to be superspecific.
    I dont want to see a brown-out happening in a large venue down southbank way on Tuesday.... :o
    Jan 2009
    62
    2 * 15AMP should be fine, unless theyre brining along dual boiler machines. La Marzocco and Expobar will require 20amp and in the unlikely case that its a synesso its 28AMPS (30amp circuit).
    Id say though that if they were bringing a DB or particularly power hungry machine, power requirements would have been one of the first things that the client would have brought up, so 15AMPS should do the trick.
    Jun 2006
    BRISBANE
    1,998
    my FAEMA 2 group 11litre boiler is between 10 and 15 amp, but 10 amp GPO is usually able to carry 16 amps before tripping the breaker on that circuit (from what I understand - Im not an electrician).
    Oct 2008
    505
    The standard wiring in Australia (2.5mm core) is rated at 16amp.
    So for a general 2 group head machine (drawing 15 amp or less) a sparky only needs to change the socket and up the fuse that the socket is on.
    20 amp is a different story. The wiring has to be changed to meet spec.
    Also a standard 10 amp plug will plug into a 15 amp socket. So you can get a GPO that has two 15 amp switches/points and your 2grp machine can plug in one and your standard grinder (10amp plug) into the other.
    Thats what I have at home.
    Feb 2009
    239
    thanks for your help guys i told the sparky to provision 2 x 15 amp GPOs for each coffee cart
    Dec 2007
    921
    Have you considered refrigeration? And possible other requirements ie extra lighting, 2 grinders?
    Apr 2008
    89
    2-group San Marinos (taking the Lisa as the most popular model in Aus) have a 4700W element - so thats 20A.
    Some are factory fitted with a 3100W element, but most Ive seen around town need the 20A power.
    Also bear in mind that SMs have a decent size water pump.
    Jun 2006
    BRISBANE
    1,998
    Thats a lot of juice - no wonder Coffee Cl_b burns the coffee....:)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 40555C4C405B5B2F0 link=1242796840/10#10 date=1243028902
    Na... Its just that they get set up to run hot so that they can scorch the milk quicker to get teh turnover.. Then the coffee gets done over as a by product :o
    Fix - Easy add more syrup :D
    General customer- Loves it :o
  1. Rancilio S24 - single group commercial machine
    By askthecoffeeguy in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th September 2008, 10:33 AM
  2. [m]: Suggestions on a 2 group commercial coffee machine
    By scoota_gal in forum General Coffee Related...
    Last Post: 8th January 2008, 05:23 PM
