Results 1 to 6 of 6
Thread: re Faema Due, power settings question
    604
    Hi All
    on the newly installed Due I noticed the two stage power- 1 and 2. Whats the deal? Is the 1 setting to leave on at night, almost a standby?
    Any help appreciated
    Brett
    Dec 2004
    Earth!
    16,150
    Re: re Faema Due, power settings question
    Im not familiar with your particular model but on most commercial machines the power switch is a 3-position one. Off, water fill, heat/full function.
    Java "Powered by coffee" phile
    604
    Thanks Java
    thats what I figured out this morning- I left the machine on 1 overnight and it was cold, but my son said he heard it refilling at around midnight- must have great ears because its so quiet!
    Brett
    Jun 2006
    BRISBANE
    2,001
    Mate - welcome to the Due Club :)
    It is a 2 position switch on these. *Position 1 is fill position (not manual fill but auto if it needs to). *Position 2 is element on. *Fully manual fill is that button on the front (you can see when you lift the drip tray that the button activates a tap in the plumbing). *I normally check the site glass when cold and if full switch straight to pos 2. *Even if down a very slight amount it will auto fill within a second or two when switched to pos 2 for the first time - if you want to be very prudent just go 1 first.
    ...Pics??? :)
    604
    Hi ozscott- it is in the other post, but always willing to show off a new toy- manufactured 12/07, in cafe Brisbane for about 6mths and then repossessed. Was unbelievably filthy when arrived. Just finished group detergent rinse- took three goes (new load of detergent until exhausted, keep repeating) each side and still not quite there. Thats the only down side- filter screen doesnt unscrew and the group seals are too new to pull apart, disassemble and soak.
    Beautiful machine
    Brett
    Jun 2006
    BRISBANE
    2,001
    Mate - looks lovely! Well done. It will make absolutely beautiful coffee. I posted some tweaks in my FAEMA Due Value thread for pressurestat settings etc if it need to be toned down if that helps.
  1. Faema Family - Power Short
    By Mischa in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th January 2012, 09:07 AM
  2. Dumb question re: 3 phase power
    By redzone121 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 2nd October 2009, 07:35 AM
  3. OMRON H3YN-2 Timer (power supply question)
    By maheel in forum Off Topic
    Last Post: 29th September 2009, 04:40 PM
  4. Replies: 16
    Last Post: 26th July 2008, 03:53 PM
