Results 1 to 3 of 3
Thread: pump pressure issue
    604
    pump pressure issue
    On the recently bought Faema, Im finding the machine is very slow to refill- much slower than the Boema or Bezzera was.
    A few points:
    The pump pressure is reading at under 8 to refill and a little bit over 8 with a blind filter
    The hose is smaller diameter than Im used to and was a bit squashed by the foot of the machine in transport- I reshaped it
    The machine was unhappy when I put in an inline water filter (right way round)- its only been running a couple of weeks without one- the filter was just out of date
    Should I replace the hose or adjust pump pressure up first? If I adjust the pump, do you adjust the screw in or out to increase pressure.
    Any help appreciated
    Brett
    Apr 2008
    89
    Re: pump pressure issue
    Replace the hoses first before playing around with pump adjustments.
    Most plumbing supplies (Tradelink/Reece) dont carry 3/8 hoses as stock, so buy some 1/2 hoses and 1/2<==>3/8 reducers. It does the same thing and can work out cheaper.
    Depending upon the age of the machine, Id recommend removing the pump and descaling it (soaking in descaling solution).
    Not sure of the Faema designs, but some types of pumps have a small wire-mesh filter on the inlet side - this could be clogged and restricting flow. If it exists, normally you cant see this wiremesh filter and it sits inside of the brass union the attaches to the pump, e.g. you have to remove the hose and union to "knock it out".
    604
    Quote Originally Posted by 66666637050 link=1246693971/1#1 date=1246754704
    Much appreciated- Ill look into it. The machine is a 2008 unit, so I doubt it would have heavy scale
    Brett
  1. Synesso Sabre pressure issue
    By BangalowBarista in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th May 2013, 09:59 PM
  2. EM6910 pressure and gauge issue
    By Davo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th December 2012, 07:55 AM
  3. Should a vibration pump pressure be set higher than a rotary pump?
    By NakiChap in forum General Coffee Related...
    Last Post: 25th June 2012, 04:11 PM
