Results 1 to 7 of 7
Thread: San Marino auto programming
    levercrema
    Hi, hoping someone can help. Just obtained a three group San Marino auto and dont know how to program the buttons. Can anyone help please.
    Thanks,
    Don
    Aug 2004
    2,312
    Re: San Marino auto programming
    Depends on the model but from memory there is a small toggle or "flick switch" somewhere in a spot where it cant be easily seen (ie not obvious & not on the front panel). When you flick it "on" it will allow you to enter programming mode. (very possibly under the front top panel).
    Thats if its "electronic". The "later" "auto timer" models also had a touch pad so they looked similar to an electronic touch pad model but the system for that was different..it escapes me at the moment but I think you turned a kind of adjustable thingamajigger that stuck out of the touch pad.
    I did say... "from memory" *;) !
    Regardz,
    Attilio
    very first CS site sponsor
    Jun 2008
    1,520
    i have a manual for them (and had one that had the old school timer with a "pot" you turned on the front)
    it has in the manual that there is a toggle switch on the front right inside and above the steam wand RHS.
    it also explains the procedure
    if you PM me your email address i will send you the manual....
    it is in *10 separate pdfs but :)
    Leeham
    levercrema
    Quote Originally Posted by 003423352E19052920202323460 link=1263353282/1#1 date=1263359208
    Regardz,
    Attilio
    Thanks Attilio, you are a life saver ;D. It is indeed the electronic model and Ive found the small toggle switch you mention - hidden up under the front panel. Now for a fiddle with the programs :D.
    Thanks again,
    Don
    Jun 2008
    1,520
    it also says that some models do nto have the toggle and holding the "program" button in till the lights flash
    and some models have a key you insert......
    I had a laugh lots of options :D
    if it still does nto work it might be a flow meter issue as one of my machines had that problem and it was not the programing
    Aug 2004
    2,312
    glad to help DrDregs
    Regardz,
    Attilio
    levercrema
    Thankyou to Attilio and Maheel for the advice.
    The monster is now working and sitting happily on the back deck dispensing the odd espresso - connected to the garden hose and only one element cos if I plug both in I fear 6000watts and 20amps will probly send the house into orbit. With me sitting in a crater holding a smoking group handle.
    Not allowed to bring it inside cos its bigger than the whole kitchen :(.
    Thanks again,
    Don
  1. Programming Klub N2 button pad
    By bassway in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd October 2018, 03:19 PM
  2. Semi auto 1 group with auto steam?
    By Gman01 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th June 2013, 01:44 PM
  3. Change programming
    By becster54 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 23rd November 2011, 10:47 AM
  4. EM6900 Programming
    By A_M in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th April 2010, 05:18 PM
