Results 1 to 9 of 9
Thread: Boiler leaking around fitting, who to fix it?
    Aug 2009
    472
    Hi All,
    Just after some advice on who i should take the boiler from my 2group BFC to to fix it. Its leaking around one of the fittings (lower boiler level sight glass pipe).
    Let me clarify, the pipe itself is not leaking, it is leaking between the boiler and the fitting itself where i presume the fitting is ?silver soldered? to the boiler?
    Is this a job for a plumber?
    Thanks in advance...
    Jul 2008
    Port Fairy
    2,993
    Re: Boiler leaking around fitting, who to fix it?
    Sight unseen is it a split fitting or a crack between the pipe and first fitting?
    For safety/insurance reasons DLI certified welders or boiler qualified person/companies. In practical terms a good plumber with experience (not every plumber) in silver soldering should get it done for you.
    Aug 2009
    472
    im pretty sure the fitting itself is fine. Are they silver soldered into the boiler??
    17,098
    Quote Originally Posted by 6E4A50404B42230 link=1309149614/2#2 date=1309175738
    Usually Silver Brazed as opposed to the low heat type Silver Solder, if thats what you meant Mischa... :-?
    Jul 2008
    Port Fairy
    2,993
    As Mal mentions high temperature filler with Silver content with Gas as opposed to soldered with an iron. And yes they will be sweated into the boiler as a separate fitting.
    There will be the odd exceptions to that if there is a raised section in say the end plate casting and the fittings are threaded into it.
    Take a pic :)
    Aug 2009
    472
    Thanks guys... way out of my league for repairing. Ill take it to the local engineering shop, they know their stuff :)
    Lucky me i get to take the boiler out... again
    Aug 2009
    472
    Ended up costing $40 at the local engineering place in artarmon. Im happy to pass on their details to anyone interested :)
    17,098
    Sounds like a very fair price Mischa... 8-)
    Whats the quality of the work like?
    Aug 2009
    472
    Always top notch. Ill take a photo.
  1. Rancilio S20 - leak in a brass fitting
    By andrewT in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th January 2012, 09:02 PM
  2. Fitting for plumbed in drip tray.
    By mcsblues in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th December 2011, 05:16 PM
  3. Faema PF fitting a Giotto?
    By james74 in forum Brewing Equipment (non-machine specific)
    Last Post: 13th September 2008, 08:44 AM
  4. Silvia PID fitting service
    By TC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th June 2008, 09:57 AM
