Results 1 to 8 of 8
Thread: Reprogramming a Rancilio 2 Group DE Model
    Jun 2006
    11
    Hi Folks,
    I have a 2 group Rancilio Machine (System DE) model and it has the standard volumetric keypad but I cant seem to get it into programming mode. Any ideas how you do it? or is it one of these that you need to pull the top or sides off and flick a toggle switch?
    3,498
    Re: Reprogramming a Rancilio 2 Group DE Model
    Dont know about the Rancilio but the La Cimbali (and some other brands) are placed into program mode by holding the stop/start button for >10 seconds (water runs from the group during that time)....
    You hear an audible beeping, or see a flashing light to let you know you are in program mode.... (and water flow stops).
    Then press and hold (press and release on some makes) the button to be programmed for the flow (with PF dosed and tamped as normal)....
    At the end of the desired volume either release the button (if you have to hold it to get flow from the group) or press the same button again (if it continues to flow following the quick press)...
    When all buttons are programmed correctly, press the stop button to save your settings....
    Some machines (La Cimbali) you have to do each group seperately others - you do one group it sets the volume for all groups....
    Not sure if this will work for your machine.... but might be worth trying.
    Good Luck!
    Mar 2006
    89
    Hi CafeMan,
    Do you have an email address with 3MB free space?
    Ive got the manual in PDF form if you want it.
    Thomas from Mocopan sent it to me recently for my S27 and it covers all the S-series, Midi, Tecna, System and System/LE models.
    Im pretty sure itll show you how to reprogam your keypad buttons - it looks to be the same as my S27.
    PM me your email address if you want to keep it out of public view.
    Frankie
    Jun 2006
    11
    Thanks gz20tt, Ill PM you my details.
    Thanks Again
    Cafe Man on Wheels
    Mar 2006
    89
    CMOW,
    email sent.
    Hope its got everything you need.
    Frankie
    Mar 2006
    89
    Cafeman,
    any further news on this?
    Did the PDF make it through to you?
    And, assuming it did, did the manual help at all?
    Frankie
    Jul 2015
    1
    Rancilio manual?
    Do you still have a copy of this manual?
    Thanks.
    Quote Originally Posted by gz20tt View Post
    Hi CafeMan,
    Frankie
    Dec 2004
    Earth!
    16,319
    What is the exact model and version number of your machine? Rancilio has made many different DE's.
    Java "Details matter!" phile
    Toys! I must have new toys!!!
  1. FYI - New Rancilio Silvia 2009 Model
    By dswiders in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th May 2009, 07:22 PM
  2. What model is my Rancilio coffee machine?
    By rancoffee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th September 2008, 11:45 AM
  3. Reqd help with unknown Rancilio model
    By short_black_fella in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th May 2008, 06:58 PM
