Results 1 to 2 of 2
Thread: marzocco portafilter on a cimbali?
    Aug 2006
    55
    is this possible?
    i have a marzocco bottomless PF and was wondering if I can use this on a Cimbali?
    I cant test it out as I dont have a Cimbali on hand *:(
    or if anyone lives SOR in perth with a Cimbali I can come over n test it out *;)
    3,498
    Re: marzocco portafilter on a cimbali?
    tanghy,
    I dont think it does fit... If you check out CoffeeParts Naked portafilters:
    http://www.coffeeparts.com/accessories/nakedpf.html
    This is a generic (non OEM) PF modified to be bottomless..... and La Cimbali has a unique part number (several others are shown as sharing the LM portafilter......)
    Id give Pedro a ring at CoffeeParts and he will be able to confirm - but Id imagine they have a different thickness lug, or the lug is a different distance down from the lip etc... You could possibly butcher the LM to make it fit---- but why wreck a beautifully made PF?
    And personally, I find the La Cimbali genuine PFs are fine and (other than the kudos from owning an LM PF) it wont improve your coffee....
    People have had an improvement with a bottomless PF however - probably due to less interference with the crema flowing into the cup (and you can see instantly if you have the dose and tamp correct)
  1. La Marzocco 15 Portafilter with rubber handle
    By decaf in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 18th December 2013, 10:31 AM
  2. Replies: 7
    Last Post: 24th May 2013, 07:09 AM
  3. Replies: 11
    Last Post: 31st December 2012, 10:36 AM
