Results 1 to 3 of 3
Thread: Cafe in Kiribati
    May 2009
    1
    Cafe in Kiribati
    Hi all
    I know that this similar has probably been asked before but Im hoping for a little bit of advice about a very reliable, simple to use commercial grade coffee machine to be used in a small coffee shop. However, this cafe is going to be in the country of Kiribati in the Central Pacific.
    We currently have a very small but successful coffee corner (the only real coffee in the country) and use a domestic machine, but are looking at upgrading to open a small cafe and will require a commercial grade 2 head coffee machine. There is nobody in Kiribati who supplies or repairs coffee machines or anything like that so we need one that is very, very reliable. (Fiji is a 3 hour flight away and only 2 flights a week). Most of the staff who will use it will not have personally done a barista course but will have been trained by somebody who has so it also needs to be simple to use.
    I have searched on the internet but am still none the wiser about what choice to make. Any advice or starting point would be appreciated.
    Thanks in advance
    Dec 2004
    Earth!
    15,784
    Re: Cafe in Kiribati
    Stay away from the electronics as much as possible, no matter how flash the machine may be. Due to the lack of readily available spare parts Id be looking at a single boiler HX machine like a La Cimbali or equivalent with no electronics in it at all. Just purely mechanical switches. Far fewer points of failure and with good water and with proper maintenance it should give you many years of trouble free service.
    Java "Heavy duty simplicity!" phile
    Apr 2008
    Brisbane
    5,113
    If you are so remote you would probably be better off to choose 2 manual hand lever machines
    It will take a bit of training
    Nothing much can go wrong except some seals that you can replace yourself
    If you buy 2 x 1 Groups and one breaks down you have the other still working
    Or you can get a commercial 2 group Hand pull lever machine
    La Pavoni makes them
  1. Cafe Cafe Subiaco
    By eljimberino in forum WA
    Last Post: 11th January 2013, 12:03 AM
  2. New Cafe
    By youngbarista in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th March 2011, 04:54 PM
  3. what you look for in a cafe
    By bintang86 in forum General Coffee Related...
    Last Post: 21st May 2007, 08:44 PM
  4. QLD Cafe help
    By Lovebite in forum General Coffee Related...
    Last Post: 29th May 2005, 09:50 AM
