Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By Dimal
  • 1 Post By matth3wh
  • 3 Post By Javaphile
Thread: San Marino? "Piazza DOro Espressimo" 2 group
    Mar 2011
    609
    Hey CSers.
    I volunteered to run a coffee stall at my schools fete coming up, and they hired a machine for me through a company theyve used a few times before. its the machine pictured below, "Piazza DOro Espressimo", and in my searching around have seen people say they think it might be a rebadged San Marino / Astoria / CMA machine.
    In my searching around I have also read that its a pretty lousy machine - eg here: http://coffeesnobs.com.au/YaBB.pl?num=1244714687 where Chris said it was one of the least impressive machines hes used, and scoota gal agreed.
    This is disappointing as obviously the reason I offered to run the stall was because I wanted to try and share good coffee with the school community rather than the ....... thats normally served. Ill be using my SJ and a couple of RR45s with good quality beans from a good roaster - I made sure I got to pick that.
    Does anyone have much experience with this machine? Can anyone tell me what theyve experienced its weaknesses to be, and does anyone have any tips on how to best manage its lousyness to produce coffee that I wont be ashamed to serve? (might be being a tad dramatic...)
    14,665
    Re: San Marino? "Piazza DOro Espressimo" 2 group
    You will be ok jb,
    If the coffee is good and you execute it well, I am sure the punters will be happy.
    The design of these is not much chop and they frequently run pretty hot unless they have been souped up.
    Wouldnt have one if someone was giving em away, but it will do the job.
    Sep 2011
    395
    Ohgods Ive used a similar unit to this. (older faux-wood-panel)
    Theyre "okay", though you gotta Keep the water flowing through them to keep them at a decent temp.
    Beans help a lot though, Id say that once youve got the grind dialled in, youre 90% of the way there to giving the school a darn fine coffee experience, Despite the apparent limitations of the machine.
    The one Ive used had a sticky steam-valve, but that might not be an indication of the machine you have before you.
    Jul 2012
    1
    I need help inProgramming the Portion Buttons Espressimo Coffee Machine, two group, as I bough it second hand and the buttons release two much water.
    Thank you
    Jun 2017
    1
    hahahaha That's not a San Marino
    That is a 15 amp I think 2 Group Espressimo my dear friend. They're a very good machine if your grinder is set right. Don't listen to others you have to make your own mind up but remember the grinder is more important than the coffee machine.
    16,276
    You are aware, I take it, that this thread is more than 5 years old?
    matth3wh likes this.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    907
    Love a good resurrected topic.
    Welcome glissy95 to CS.
    What is disappointing is we never got to hear the end of the story. (At least in this thread)
    Did Bames succeed?
    Did the fete raise money?
    Did he go on to become a barista or roaster or DJ for that matter?
    So many questions need answers... 🤡
    level3ninja likes this.
    Dec 2004
    Earth!
    15,106
    Bames is still active on the site, he was last on 22 hours ago. Drop him a PM and ask that he update the thread!
    Java "Update!" phile
    Toys! I must have new toys!!!
    Oct 2018
    21
    I’ll resurrect it again, I actually have one of these and was given it. They don’t run as hot as the old San Marino machine as they have an updated head and true thermosyphon, I actually had to make the restrictors bigger to get some more temp in the heads, they aren’t astounding but consistent and easy to use and a dream to work on as the flowmeters are under the drip tray and they have opening side doors to access the electronics and pump
  1. Piazza DOro Piston/Leone CMA manufactured 1 group machine
    By adfraggs in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 25th June 2010, 09:07 PM
  2. Brasilia "Cappucino" (Single group model 2003) Temperature
    By u304333 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 25th April 2010, 07:57 PM
